Tom's Hardware > Forum > Laptops & Notebooks > General Laptops & Notebooks > LCD Screen problems on a Sony pcg-grt170
Forum Laptops & Notebooks : General Laptops & Notebooks - LCD Screen problems on a Sony pcg-grt170
Archived from groups: comp.sys.laptops (More info?)
My Sony PCG-GRT170 has what I have tentatively (and definitely
non-expertly) diagnosed as a backlight problem. The symptoms:
--Everything works fine, other than the LCD. (I am typing this right
now using the computer and an external monitor).
Prior to the LCD ceasing to work, I would occasionally have
intermittent flickering. Sony online support suggested this might be
caused by the incorrect power supply, but the model number on my power
supply is correct according to their literature.
A few days before the LCD ceased working properly, I could swear I
smelled something... well not quite burning, but maybe plastic
'cooking.' At the time I wrote this off to an incipient brain tumor,
but I thought I would include this detail.
Suddenly, it all went dark.
The screen 'attempts' to light up when I change resolutions, boot up or
switch between external and main displays using the hotkey. By
'attempts' I mean I see a brief reddish flash along the right-hand side
of the screen.
I can still see images on the monitor (i.e. the windows XP logo as it
boots up), but they are very, dim. In a dark room, I see nothing at
all.
In my initial exploratory inquiries, the inverter came up as a probable
culprit. I ordered an inverter from sparepartswarehouse.com
(theoretically new), but installing it has not solved the problem.
a) what is my best next step?
b) what is the probability of having received a bad replacement
inverter?
c) what are some costs involved? I may well just buy a replacement
laptop if the price exceeds the cost of a new external monitor.
Thanks for any insights you may be able to provide.
Taylor Bryant
Sponsored Links
> or switch between external and main displays using the hotkey. By
> side of the screen.
> all.
> probable culprit. I ordered an inverter from sparepartswarehouse.com
> inverter?
> Taylor Bryant
The burning odor could well be the inverter board failing. Try here for
a replacement: http://www.sparepartswarehouse.com/ The inverter is $73,
but you should call or email if you are not certain of the part number.
Q
Reply to Anonymous
I should have made it a separate paragraph, it's a bit rushed at the
end there- I actually already ordered the replacement inverter. The
inverter I ordered from sparepartswarehouse was the exact same, but
replacing the old with the new did not solve any of my problems.
Is it at all probable that I got a bad inverter? Or is my problem
something else?
Thanks again.
Taylor
Reply to Anonymous
The problem is the backlight.
We offer LCD repair service, whether it is inverter or backlight or
both. The charge is $195, provide a 6 month warranty. Here are the
details:
http://www.portablecomputer.co­m/repair/lcdrepair.asp
Reply to Anonymous
- 0 +
If you can find out what size the lamp is, and can use a soldering
iron, you can probably get a cheap lamp replacement from Digi-Key or
Mouser. The lamp size is probably about 2-3mm in diameter and somewhere
around 325mm long, for a 16" display.
Much cheaper than a repair shop, but if you screw it up, there's no one
to blame but yourself.
Good luck!
Reply to clayton
yea, definitely it is the backlight.
You can tell because when there is some light outside, it shines and
reflects in the LCD and lets you see whats on the screen. So the LCD itself
is good, but there is no light coming from the back. If you are in a dark
room, there is no light to reflect so you dont see anything.
You will see exactly the same thing if you (in a working laptop) press the
button or switch that is pressed when you close the screen. This switch just
turns the backlight off. Now, in the luckiest case of all, your problem is
that the screen-closed-switch is stuck, but that's probably not the case
(worth to check, though)
guillermo
"Portablecomputer.com" <wesleyf@portablecomputer.com> wrote in message
news:1114618892.455309.76480@f14g2000cwb.googlegroups.com...
details:
Reply to Guillermo
Great! We do these for 169.00 plus the return ship.. Give us a buzz if
you need help and we repair a ton of these Vaio's..
Reply to Anonymous
Thanks guys, I'm glad I decided to check the thread after a few days, I
was really happy to see more advice. I am going to give the lamp a
shot, I am big into digging my own grave ;).
Hopefully, if it goes well, I will be posting some positive results in
a couple of weeks (goin' on a vacaction now, tho).
Thanks again.
Reply to Anonymous
There are 1258 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
