Tom's Hardware > Forum > Laptops & Notebooks > General Laptops & Notebooks > IBM TP A20m No Net Connection Problem
Forum Laptops & Notebooks : General Laptops & Notebooks - IBM TP A20m No Net Connection Problem
Archived from groups: comp.sys.laptops (More info?)
IBM Thinkpad A20m, ethernet problem. I'm stumped on this one.
The drivers are installed and appear to be working for the 3Com
Ethernet adapter, but I still can't connect to a network (ie get a link
light). The little network symbol in the lower right corner (Win2K) has
a red X. The cable I use connects my A22p to the network just fine, so
unless I'm missing something it's got to be the laptop.
Any ideas on what's wrong, how to diagnose, or how to fix it?
Thanks!
Sponsored Links
try a pcmcia network card
"Coffee" <xanthinine@yahoo.com> wrote in message
news:1114567570.612982.85780@o13g2000cwo.googlegroups.com...
> Thanks!
Reply to BigJim
Are you sure you have a combo card in it? Not all the A20m machines came
with a combo modem/ethernet card, but just a modem card, even though they
all have the RJ45 connector.
What's the model number of your unit?
Regards,
James
Reply to Anonymous
Yes, it worked several years ago in the good ol' dorm rooms. I bought a
wireless pcmcia card when I moved into an apartment with shared wifi. I
first realized the "other" network card wasn't working when I recently
went to a hotel that had wired ethernet and I couldn't connect. After
taking the laptop to work and trying to plug into the network there,
that confirmed the problem was the laptop.
Also, the drivers install and say everything is working fine, but the
model number is 2628-4xu.
Thanks!
came
they
> Regards,
> James
Reply to Coffee
> a wireless pcmcia card when I moved into an apartment with shared
> wifi. I first realized the "other" network card wasn't working when I
> recently went to a hotel that had wired ethernet and I couldn't
> connect. After taking the laptop to work and trying to plug into the
> network there, that confirmed the problem was the laptop.
Are you using IBM's Access Connections?
Try removing the WiFi and then connecting the RJ45 cable.
Regards,
James
Reply to Anonymous
> Regards,
> James
it may be a physical connection problem. Open up your mini pci door,
the card is probably seated ok as you were able to load the driver.
Make sure the ribbon connectors at the other end is fitted snugly and
not loosen at all.
Reply to Anonymous
No, I am not using IBM's Access Connections. A reformatting to load
Win2K took care of that.
I already tried removing the wifi card, but that doesn't seem to get me
an actual connection. I think the problem may be some type of physical
error or misalignment.
Reply to Coffee
Update:
Well, I tried replugging everything and it still didn't work. After
cursing the universe for a few minutes I slapped my laptop and it
actually connected! I guess something had come loose and giving it a
slight jolt put it in its place, so to speak.
Thanks for all your help, everyone!
> not loosen at all.
Reply to Coffee
There are 676 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
