Yes No
Ads
Tom's Hardware > Forum > Systems > New Build > Recommended power supply unit (PSU) for a new PC build?
Forum Systems : New Build Recommended power supply unit (PSU) for a new PC build?
Im new here :) . A few Google searches have shown me that there are many informative and helpful
people on this forum who may be able to help me in regards to the subject matter.
now my question is; I'm attempting to build my first PC and need advice as to which power supply would be adequate for my system. My specs are;
Intel Core i7 2600 processor
Asus P8P67 Deluxe motherboard
8GB Corsair Vengeance DDR3 RAM 1600Mhz
2TB Hard drive 5400RPM
x2 Blu Ray/DVD RW/Light-scribe drives
Nvidia Geforce GTX 560 Ti Graphics card
PC case with 7 Integrated fans (x1 with LED)
Not sure about a sound card as i may use on-board sound. Also, is a CPU cooler necessary as im
not planning on overclocking. All suggestions are welcomed and greatly appreciated.
Reply to corleone11
Do you plan future SLI?
I'm curious, why the 5400rpm drive? That's gotta really hurt your performance.
------------------------------ Core i3-2100/Asrock H61/8GB1333/XFX HD5850oc/WD Black 500/Antec 300/Antec EA380w bronze
Currently playing Deus Ex:HR a second time on Hardcore
Reply to geekapproved
- 0 +
Hi,
A 500w PSU should be plently to power that system. Make sure you buy a good brand however as this is a vital part of any computer. Way to many people buy value PSU's only to regret it later. Brands i can recommend are Corsiar / Seasonic / XFX (XFX PSU's are made by Seasonic).
Example: Corsair HX520 http://www.newegg.com/Product/Prod [...] 6817139001
Reply to dsM22
- 0 +
http://www.tomshardware.com/forum/ [...] ild-advice
------------------------------ "God invented Google so you would stop asking stupid questions."
Reply to Why_Me
Going to give future SLI a miss. I assumed that with an adequate amount of RAM, the RPM of the hard drive wouldn't matter too much?
or have i just made myself seem very computer illiterate :??: lol
Reply to corleone11
dsM22 wrote :
Hi,
Thank you for your recommendation, i really appreciate that :D
Reply to corleone11
- 0 +
HDD Spin Speed is very important, getting a better quality HDD will give a noticeable improvement to things like windows boot time.
I'd recommend the Sanmsung SpinPoint Series ( . The HDD's are well priced and offer great read / write speeds for a 7200rpm HDD.
http://www.newegg.com/Product/Prod [...] 13434c9757
Getting 2 of those drives and putting them in a RAID 0 config will give you even more speed and improved performance.
EDIT - RAID 0 effectivly combines 2 HDD's into 1 and shares the data between them (in very small strips) this effectivley doubles he speed of the HDD as it read and writes from them both at the same time. (Laymans Terms)
Message quoted 1 times
Message edited by dsM22 on 04-11-2011 at 10:24:38 PM
Reply to dsM22
- 0 +
Quote :
lso, is a CPU cooler necessary as im not planning on overclocking
The CPU will come packaged with a stock cooler which willbe fine at stock speeds.
Reply to dsM22
Thanks for clearing that up. Im currently still using a 320 GB samsung drive in my 7 year old PC and have never had the slightest hiccup, so can't deny their quality. As im located in the UK, purchasing from Newegg isn't gonna happen as they don't do international shipping :cry: . I should've mentioned before that the main reason i settled for that particular drive is because the cost was within my marigine, and is a reputable quality brand (Seagate Barracuda). The only alternative was Western Digital, which i refuse to touch with a 50 foot barge pole due to their poor standards in quality :non: . Seriously, the internet is littered with people complaining on forums about loss of data due to the hard drives dieing well within warranty :ouch:
In regards to RAID 0, am i right in saying that as the same data is written to both drives, won't this reduce reliability? Because if one drive fails, the other drive(s) are effectively filled with useless, unfinished data. Seems a little too risky for me :sweat: . Thanks for the
Reply to corleone11
dsM22 wrote :
Quote :
Thanks for the help and advice, dsM22, i really appreciate it.
Reply to corleone11
- 0 +
According to NVIDIA's specifications the minimum power supply requirement for a GeForce GTX 560 Ti is a unit with a minimum of 500 Watts or greater and with a minimum combined +12V current rating of 30 Amps or greater.
Reply to ko888
Get a high efficiency 500 watt, or something with a bit more wattage to allow for upgrades. Never cut yourself short when it comes to power supplies....
here is an example: http://www.newegg.com/Product/Prod [...] 6817341022
Reply to benson733
- 0 +
Antec High Current Gamer 520W 80Plus Bronze for ~£60 is probably your best bet.
Reply to Silvune
- 0 +
If efficiency matters a lot to you, get a Seasonic X-560; it is 80+ Gold and does not need to run its fan at low loads.
Otherwise, for a single GTX560, 500W is sufficient. A quality modern PSU has full range active PFC (no little voltage switch) and at least 80+ certification for efficiency. Antec, Seasonic, Corsair, Enermax, and XFX are among the quality brands. Many of the better ones (some Antec, Corsair, and XFX) are all built by Seasonic. Delta builds some of the other good Antecs.
Reply to jtt283
- 0 +
That is exactly right! If you want to improve performance and reliability, you could use a RAID5 setup. it requires at least 3 drives though. :D
Reply to clarkjd
I just checked, your right! why didn't i think of doing that :heink: Thanks!
Reply to corleone11
Thank you for the recommendation. I'll have a look on amazon or ebuyer as Newegg don't ship to the UK. Thats such a bummer
because Newegg seem to have EVERYTHING at such great value :( . Its so true about not cutting yourself short with the PSU, if there's
one thing i know for sure about computers, is that the PSU is the most vital component.
Reply to corleone11
Yep, thats what everyone seems to be recommending as they are clearly a quality brand, thanks!
I found that particular PSU on ebuyer for £56.61 with free delivery :sol: Seems like a no brainer :D
Reply to corleone11
yeh i can be a bit of an efficiency freak at times :whistle: so the fan would kick in when the systems being strained, and remain idle when its not? Seems
like a great idea and thats something i may definitely consider. Yeah i think im gonna go with either Antec or Corsair as they appear to be of the utmost
quality PSU's. I appreciate your input jtt283 :)
Reply to corleone11
I personally wouldn't use a RAID 0 config, knowing my luck :na: So is a RAID 5 array more failsafe? If i have 2tb worth of data over 3 drives, and one fails,
will i still have 2tb afterwards?
Reply to corleone11
- 0 +
With RAID5, if a drive goes bad, you replace that drive and the RAID5 will rebuild the missing data, kind of like using a parity bit to prevent bad memory.
Message edited by clarkjd on 04-12-2011 at 08:56:02 PM
Reply to clarkjd
ok, so there's less risk with RAID 5 array. I guess it would just be a case of trying to find the most cost effective solution in RAID 5.
But what if the parity data becomes corrupt or if two or more drives fail or become corrupted at the same time :o i should stop being so negative, shouldn't i :lol:
Message edited by corleone11 on 04-12-2011 at 09:28:31 PM
Reply to corleone11
- 0 +
I am reminded of the old Benny Hill routine about bombs on airplanes: He said that the chances of there being a bomb on an airplane were 1000000 to 1. and the chances of there being two bombs on an airplane were 1000000 times 1000000 to 1. so be safe...Always carry a bomb when you fly!
Raid 5 is extremely fault tolerant. The "parity bit" isn't only on one drive, it is striped across all the drives in the array, as is the other data. and, you are right, if you lose enough drives in the array, you will lose the data. Usually, though you won't lose multiple drives at the same time, and that gives you some time to replace a faulty drive, and rebuild the array. You need to keep a spare drive available for just such an occurrence.
Reply to clarkjd
I see the correlation :lol:
Ok, now i understand. Thanks for clearing that up!
Reply to corleone11
There are 1841 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
$600 Budget Gaming Build - Advice Appreciated
By coffeecoffee, 7 hours ago:
Alright, your on the right track. There are a few changes I would like to make if I...
Best offers
Top experts
