Solved
Is this power supply compatible with this computer?
Power Supply:
http://www.amazon.com/gp/product/B001L0N1M2/ref=ox_sc_act_title_1?ie=UTF8&m=ATVPDKIKX0DER&tag=vglnk-c1001-20
Computer:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02640178&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Someone on yahoo answers said that i would need a M-ATX Power supply or something? Because its a uATX mobo.... I don't know if his answer is legit though.
I don't know much about computers... I just wanna get a 500w power supply in this comp so i can upgrade it to a HD 6790. If that one isn't compatible could someone tell me one that is at 500w, that is not going to die in 6 months.
5 answers Last reply Best Answer
More about power supply compatible computer
  1. Best answer
    The computer is in a mid-ATX case (ATX). The power supply you linked is an ATX power supply.
    Yes they are compatible!
    I don't know the quality of Diablo PSUs. However, I know that Corsair PSUs are good and reliable.
    I suggest this one: http://www.newegg.com/Product/Product.aspx?Item=N82E16817139027 ($40 after MIR)
    Thanks, I didn't that sounded right... The uatx crap or whatever....
    I think i might get the corsair, because all i've heard was positive things about their products.
    Yes, get Corsair, and get it on sale! $40 after MIR - http://www.newegg.com/Product/Product.aspx?Item=N82E16817139027
  4. Best answer selected by Keithred92.
  5. Thank you!
Power Supplies Computers Compatibility Components Product
