I was wondering where I look to figure out if my motherboard is compatible with SSDs and which SSD's it's compatible with.
my motherboard is: GIGABYTE GA-MA770T-UD3 AM3 AMD 770 ATX AMD Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128451&nm_mc=TEMC-RMA-Approvel&cm_mmc=TEMC-RMA-Approvel-_-Content-_-text-_-
under product details - storage it says: Pata, Sata 3gb/s, and Sata Raid 0/1/0+1
Would it work with a e.g. Samsung 830 Series 2.5" SATA III SSD?
Or just in general SSDs
Thank you
Thank you
