Hello Tom's community,
I am looking to buy a new computer and I still have some questions about what components I should choose.
Approximate Purchase Date: Spring or Summer 2011
Budget Range: 700-900$
System Usage from Most to Least Important: MMORPG Gaming, RTS Gaming, some shooters... pew pew
Country of Origin: Canada
Preferred Website(s) for Parts: tigerdirect.ca, newegg.ca, pccyber.ca, ibuypower.ca
Parts Preferences: I am looking for a middle range market computer. I dont want to buy the lastest components but I want something that will last for at least 2 years. It's my first build and I'll would like to have your opinion on my build and maybe suggest another one.
Here's what I found for now :
CPU : Intel Core i5 760 Processor - 2.8GHz, LGA 1156, 8MB L3 Cache, Quad-Core, Lynnfield
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=6524800&CatId=4729
Video card : Radeon HD 6850 Video Card - 1024MB, GDDR5, PCIe, mini-Display Port, HDMI, Dual DVI
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=6817311&CatId=3669
Ram : PC12800 RAM - 8GB, DDR3, Dual Channel, Cl 9, PC12800, 1600MHz(4x2GB)
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=5082129&CatId=4527
Motherboard : Intel H55, LGA 1156, Micro ATX, DDR3, HDMI, USB 2.0, SATA II, Gigabit Ethernet Port
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=5605770&CatId=5195
I really dont know how to choose a motherboard... its a pretty random choice. Its the HDMI that provoke that choice.
Powersupply : Ultra LSP750 750-Watt Power Supply - ATX, SATA-Ready, SLI-Ready, 135mm Fan
http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=3276567&Sku=ULT-LSP750
Does it make a difference one or another ?
Harddrive: meuuh.. I have a 500gb 7200rpm WD.
Overclocking: Why not ?
SLI or Crossfire: I would tend to say no
Monitor Resolution: 1920x1080, 1920x1200 (I'm playing on a 32" TV and sometimes on my 60'')
Additional Comments: ...
Thanks for your help!
-SqueezeWell
-SqueezeWell
