I am trying to decide which of these two monitors I should get
http://www.amazon.com/ML228H-22-Inch-Ultra-Slim-Widescreen-Monitor/dp/B00413PHEQ/ref=sr_1_1?ie=UTF8&s=electronics&qid=1297043467&sr=1-1
OR
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236059
The second monitor is a 23 inch while the first is a 22. However, the first is a lot cheaper and is a led. I am having trouble deciding which of these monitors I should get, especially since i am having my computer double as a tv using a tuner in a small room and I am not sure if a 22 inch monitor is big enough. Im not even sure if a 1 inch difference makes that big of a deal. I would appreciate any opinions on this, or any other good deals you may have found on monitors . Thanks!
OR
