Archived from groups: comp.sys.laptops (More info?)
The usb port on my ThinkPad hasn't been functioning recently. I have posted
some screenshots at www.geocities.com/areluc/thinkpad/. As you can see
there, I have a mulfunctioning USB Root Hub. When I go into properties, it
tells me I should update the driver. I have downloaded a usb driver for my
specific laptop model from the IBM site. However, when I try to use it by
pointing to its location, the system tells me that the best driver is
already installed and there's no way I can change it. Same with MS Windows
Update. When I remove the hub and even the host controller, they
automatically reinstall themselves exactly as they were. As a result,
nothing I connect to usb port works! Does anyone have any idea how I can fix
this?
Thanks,
Lucar
Sponsored Links
Tom's Hardware > Forum > Laptops & Notebooks > General Laptops & Notebooks > ThinkPad problem
There are 841 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
