Will My 380w Power Supply Support These Specs???
  • Power Supplies
  • Support
  • Components
Last response: in Components
July 16, 2011 6:25:14 AM
Hi friends!
This has been causing me a whole lotta stress and confusion considering the wide selection of computer hardware.
I have a stock 380W power supply. I am wondering if it will support what i plan to install or will i have to buy a more powerful supply?
my specs next week will be,
MOBO: M4A78LT-M
PROCESSOR: AMD Phenom II x2 565 80w
RAM: DDR3 2 Sticks 2x2GB
GRAPHICS CARD: Asus radeon HD 5450
HARD DRIVE: SATA 1 TB
DISK DRIVE: DVD+R DL
FRONT BAY CARD READER
And 4 cooling fans not including heatsink.
Will my 380w power all this? I also plan to over clock my phenom.
Please i already tried the power supply calculator and they all tell me something different, so any of your opinions will be highly appreciated thank you!!
More about : 380w power supply support specs
a b ) Power supply
July 16, 2011 6:37:43 AM
enough ... minimum PSU for Radeon 5450 is 22A at 300W, But don't use PSU from Stock case .
power consumption Radeon is just use 380W pure PSU minimal 80+ certificate
* System in IDLE = 154 Watts
* System with GPU in FULL Stress =177 Watts
* Difference (GPU load) =23 Watt
m
l
July 16, 2011 6:44:06 AM
This 380w is only 12v - 15A... So i was looking at that 500w corsair, im guessing that'll do the job right?
m
l
a b ) Power supply
July 16, 2011 6:51:22 AM
yep ... 500W corsair very very enough for 5450
m
l
July 16, 2011 6:53:45 AM
Sorry to bother you, sadly I have been struggling with this issue for about a week now. So for the setup I plan to put together you are pretty much saying that my PSU is barley enough to power my Radeon?
m
l
July 16, 2011 7:04:13 AM
What if i decide to install an HIS Radeon HD 4670 instead? I will still be fine with the 500w corsair and being overclocked?
m
l
a b ) Power supply
July 16, 2011 7:30:13 AM
i dom't know your PSU 380 Watt review and i don't trush PSU from stock case .
Corsair 500 watt is good , i use PSU corsair 550W VX for phenom II X6 overclock at 3.8Ghz and radeon 4850 Oc too for dailly till now safely
m
l
a c 92 ) Power supply
July 16, 2011 4:47:26 PM
380W doesn't tell us anything. I can point out a review of a Diablotek 500W unit that can't power your setup, but a 380W that can. We need more details then "380W".
m
l
a c 1204 ) Power supply
July 16, 2011 5:12:06 PM
When determining what power supply to purchase you should not be focusing on the power supply wattage.
The most important specification you should focus on is the power supply's +12 Volt continuous current rating. The CPU and GPU are powered by the +12 Volt rail(s).
A Radeon HD 5450 has a maximum board power of 19 Watts. This means that the graphics card itself may draw up to 1.6 Amps from the +12 Volt rail. Your 380 Watt power supply with its +12 Volt current rating of 15 Amps, which is considered weak, should be able to handle a system with this graphics card assuming your 380 Watt power supply is actually able to deliver this rated 15 Amps of current.
A Radeon HD 4670 has a maximum board power of 59 Watts. This means that the graphics card itself may draw up to 4.9 Amps from the +12 Volt rail but will actually draw up to 5.4 Amps if you run the FurMark test utility. Your 380 Watt power supply may still be able to run your system with this graphics card because under a typical gaming load the graphics card's current draw is 4 Amps leaving 11 Amps to power the CPU, motherboard, hard disk drive, DVD drive and cooling fans.
m
l
July 16, 2011 6:36:24 PM
My power supply came with the Asus stock case, its called an AcBel 12V - 15A.
m
l
July 16, 2011 6:40:55 PM
The reason I chose the radeon 5450 was because its low power consumption. I was hoping to be able to safely power
MOBO: M4A78LT-M
PROCESSOR: AMD Phenom II x2 565 80w ( I want to OC to make it phenom II x4)
With linksys wireless n usb adaptor and asus wireless headset.
Will my 380w AcBel 12v - 15A be able to handle that?
m
l
July 16, 2011 7:44:00 PM
What is the Model number of that AcBel Polytech Inc. 380 Watt power supply?
I thought it should have at least two +12 Volt rails.
m
l
July 16, 2011 9:26:23 PM
PC9045-ZA1G is the model number
m
l
July 16, 2011 9:36:14 PM
I have another 380w power supply. Maybe this one is better and will be able to support the specs I have listed above?
My other 380 PSU is a
Antec
Model Number: TPII - 380
I checked and this one has 16A while my other one has only 15A not much of a difference...
Seems the Antec might be slightly better then the AcBel.
But is it enough to safely power everything listed above?
m
l
July 16, 2011 10:07:01 PM
Antec
The Antec TruePower II 380 Watt Continuous Power ATX12V v2.0 (TP-II 380) has a combined +12 Volt continuous current rating of 28 Amps.
It will power a system using either of the graphics cards you have mentioned with no problem with plenty in reserve for overclocking the CPU and GPU.
m
l
July 16, 2011 10:24:28 PM
This power supply's combined +12 Volt current rating is 18 Amps which should in theory be able to power a system using either of the graphics cards you have mentioned.
m
l
July 17, 2011 4:35:25 AM
I had a more powerful system running on a 300W so you will be fine
m
l
