Tom's Hardware > Forum > Laptops & Notebooks > General Laptops & Notebooks > Help with ps/2 mouse on Toshiba Satellite 2550CDT
Forum Laptops & Notebooks : General Laptops & Notebooks - Help with ps/2 mouse on Toshiba Satellite 2550CDT
Archived from groups: comp.sys.laptops (More info?)
My laptop doesn't see a mouse on PS/2 (working good with USB). When I forced
it to install a mouse on PS/2 port it showed a conflict with IRQ 12, that is
always used by AccuPoint. No result was obtained by simple managing Setup,
Start_Settings_Control Panel..., etc. The port looks to be good as it
"makes" a conflict. Can anybody help me? I went through Google with it,
but... no result.
Thanks
Sponsored Links
"Kuna&Zagiel" <bknapik@remove_this.geonafta.krakow.pl> wrote in message news:d4ta7o$eft$1@nemesis.news.tpi.pl...
Date: Fri, 29 Apr 2005 14:39:55 +0200
When I forced it to install a mouse on PS/2 port it showed a
conflict with IRQ 12, that is always used by AccuPoint. No
as it "makes" a conflict. Can anybody help me? I went through
Google with it, but... no result. Thanks
Well my 2595XDVD might have the same BIOS Setup as yours. And my
BIOS (CMOS) setup has a setting that allows one to disable one or
the other or to allow both to work at the same time. Sounds like you
need to check your setting.
Cheers!
__________________________________________________
Bill (using a Toshiba 2595XDVD under Windows 2000)
-- written and edited within WordStar 5.0
Reply to Anonymous
There are 1225 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
