Yes No
Ads
Tom's Hardware > Forum > CPU & Components > Power Supplies, Cases & Mods > [Solved] 400 watt Power Supply hp p6100z compatible
Forum CPU & Components : Power Supplies, Cases & Mods [Solved] 400 watt Power Supply hp p6100z compatible
Best answer from ko888.
How can I determine which PSU will be a clean retro-fit in my HP p6100z desk top? Th existing 300 w PSU is Bestec model A3X0300DSWCREVA.
Thanks,
Dave
Reply to jdr37
Looks to be a std size mini tower http://bizsupport1.austin.hp.com/b [...] peId=12454
Any std size PSU should work for example the Antec EA380 which is a very good PSU in the 400watt range http://www.newegg.com/Product/Prod [...] 6817371033
Reply to rolli59
Best answer
Thanks,
Dave
Your current Bestec ATX0300D5WC Rev A power supply is a standard ATX12V form factor power supply unit with dimensions 5.9" W x 3.39" H x 5.51" D.
Are you upgrading the power supply because you've purchased a new graphics card? If yes, please specify the make and model of the new graphics card.
Reply to ko888
There are 1935 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
3930k idles low, boots hot, then cools?
By DJDeCiBeL, 4 hours ago:
Check your temps with HWMonitor, Core Temp or RealTemp. SpeedFan seems to be wrong more...
Best offers
Top experts
