Speed of wireless router not powerful enough?
martinpat29
Hello,
We are supporting 3 wireless laptops and a wireless desktop using a standard router connected to the cable modem on a desktop upstairs. All day we are resetting the router. What do we need to do.
Thank you.
martinpat29
We are using Netgear at 54 mbps. The house is a newer brick two story. Since I cleared any other radio waves away from the router it seems to be doing better. Maybe the cordless phone was causing the problem. Thank you for your input.
Also, I'd like to mention something else for other people that might run into a similar problem. When I turned off my smart phone and removed the sim card was when I really noticed the difference. I have a new carrier and phone with the wifi enabled and have had no problems.
Thanks,
Pat
