New Build-Post code problem
I have an Asus rampage IV extreme with a GTX680. I reiceve a post code A2. The book says "IDE Detect" but I am not sure what to do. I am running an SSD via SATA.
3 answers Last reply
More about build post code problem
  1. Check your BIOS and see if you need to change the setting from IDE to ACHI
  2. I have not been able to post into bios. I do know th manual says that the intel sata 3 ports are set to ACHI. I installed the optical drive on other ports, in fact I have tried them all.
  3. No offense...are both 6 pin power cables connected? Also, what PSU are you using?
Asus New Build Motherboards
