Hi All,
Having some problems regarding my Graphics card.
Basically this started a few months ago with my original Geforce 8500GT, it came with my PC when i bought it, had been running fine with no problems then it started acting up. windows couldn't find it, Sometimes it would run as it should then about an hour into it the sceen would flicker/flash and eventually just shut down my monitor into standby. Sometimes i would get a message saying the display adaptor had encountered a problem but had recovered, other times when i rebooted after the screen turning off it would have switched back to default onboard graphics and there was no sign of the card.
Anyway after removing it and having a look i discovered that a couple of the capacitators were leaking, figured that was the problem and it was pretty much done in...time for a new card!
Fast forward a few months, don't really have to the cash to upgrade to a better card at the moment so i picked up another 8500GT to replace the original as it had done me fine up until the problems started...
Install the new card, all is fine, windows installs it ok then asks me to reboot...get as far as the windows logo then black screen, left it for about 20 mins still nothing so i switch off and reboot...everything seems to load ok no problems.
I download the latest drivers from Nvidia site, install and reboot, everything seems to be fine...then the flickering starts again like it did the previous card and switches of the monitor, reboot and windows cant find any trace of the card...back to square one!
I removed the card, booted in safe mode and ran driver sweeper to get rid of the old drivers, put it all back in, booted up, again get to the win logo and then nothing...eventually it gives me a blue screen and reboots itself then tells me windows didn't load properly and wants to to perform a system restore which i do, windows finds the card again no problems.
Needless to say it didn't last!
I'm now thinking there could be a problem with my MB as i did upgrade my PSU to a 550 inbetween all this and since this has now happened with 2 of the same cards...i really don't have a clue!
Here is a link to my motherboard if it helps any!
Can anyone shed any light on what could be going on here?
Sorry for the long post, was trying to cover as much as possible, any help would be appreciated.
Thanks.
Thanks.
