Reference GTX 560 TI running hot
Hi Guys.
I`ve been having major heat problems with my inno3d gtx560 (reference cooler) and want some advice on an Aftermarket cooler.
To put it into perspective I`m running E8400 at 3.6ghz on 680i under a Zalman 9700 in an Antec P180. intelburntest load on Cpu reaches 67 degrees.
When i load Cpu with Intelburntest and load the Gpu with Furmark i get 78 Degree on Cpu.
Gpu hovers around the 90 Degree mark when stress testing.
This Gpu is driving my temps up around 10 Degrees, coming off a 8800gt this is quite a shock.
Any advice on a Cooler which covers the VRM`s would be greatly appreciated.
Extra information: I reapplied thermal paste to Gpu which dropped temps by about 3-4 degrees and I have two 12cm fans in a windtunnel pointing straight at the Card.
With side off case the temps are generally 5 degrees cooler.
Ask the community
