Hello I am building a new system and would like some advice on what to get. I don't know when I will purchase it but probably sometime next month. My budget is $1,200 or less. I will be using this system for gaming. I would prefer it if the parts were from Newegg.com but it does not matter very much. I am looking for a good 120mm fan, a surge protector (link please) , and a good power supply for what i'm building. Also I am wondering if the parts I picked below are all compatible with each other. Please notify me if I'm forgetting something a computer needs. I'm not going to crossfire/sli. Oh and my monitor is 1400x900 and I am not going to overclock.
Case:COOLER MASTER HAF 922 RC-922M-KKN1-GP Black Steel + Plastic and Mesh Bezel ATX Mid Tower Computer Case
CPU:Intel® Core™ i5-2500K 3.30 GHz 6M Intel Smart Cache LGA1155
CD:24X Double Layer Dual Format DVD+-R/+-RW + CD-R/RW Drive (BLACK COLOR)
MEMORY:G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBRL
MOTHERBOARD:[CrossFireX] Asus P8P67 Intel P67 Chipset DDR3 ATX Mainboard w/ UEFI, DIGI+VRM, 7.1 HD Audio, BT GO!, GbLAN, USB 3.0, 2x SATA-III RAID, 2 Gen2 PCIe, 2 PCIe X1 & 3 PCI [B3 Stepping]
SOUND:HIGH DEFINITION ON-BOARD 7.1 AUDIO
VIDEO:HIS H687F1G2M Radeon HD 6870 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity
NETWORK: on board Gigabit LAN Network
Hard drive:SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Surge protector: Undecided (Do I need one?)
POWERSUPPLY: Undecided
Fan: Undecided 120 mm fan.
Heat Sink Fan (Is this the same as a fan?): COOLER MASTER Hyper 212 Plus RR-B10-212P-G1 "Heatpipe Direct Contact" Long Life Sleeve 120mm CPU Cooler Compatible Intel Core i5 & Intel Core i7
Note to self: (Don't read unless you wanna waste time.) Get links to everything. Also get Anti Static Wrist Band.
Motherboard : http://www.newegg.com/Product/Product.aspx?Item=N82E16813131705&cm_re=asus_p8p67_intel_chipset-_-13-131-705-_-Product
Memory: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231311&cm_re=G.SKILL_ripjaws_series_8_gb-_-20-231-311-_-Product
