Closed Solved
Memory&Mobo Problem
Hello guys im new in this forum and i have a noobish question can anyone help me?
Recently i bought an Msi g41m-p26 Mobo and it says it only supports 1066 ddr3ram, but im using it with 1333 one.. does it affect performance..and my processor its pentium 4 prescott HT..with only 800fbs.. it its compatible with the 1333? my pc its so freaking slow :S and the usage cpu its more than 80% always.. i dunno if my ratio its bad, or my processor isnt compatible, can anyone help me please? :(
8 answers Last reply Best Answer
More about memory mobo problem
  1. Welcome to Tom's Forum! :)
    The DDR3-1333 kit will run at a reduced Frequency (1066 or 800 MHz) by default so it's fine to run the kit.
    MSI G41M-P26 - http://www.msi.com/product/mb/G41M-P26.html
    - Supports FSB 800/1066/1333 MHz
    - Supports two DIMM DDR3 800/1066/1333*(OC) DRAM
    To remedy the 80% try running MSCONFIG and turn-off the Startup items (Disable All), and also Services [x] Hide All Microsoft Services ... then deselect the unneeded items, click OK and reboot.
  2. Thank you so much for the answer :)!
    But the processor, its ok? i mean..like 2 months ago i had a worst pc..and i could run games better than this one..so im thinking that something its wrong ..since i have a better pc the FPS should be higher but..:( the FPS are so bad now.
  3. If one of the sticks is bad or improperly seated (bad) then sure it's the RAM.
    I don't know which OS you have, but a tell tale is if the Hardware reserved is > (greater) than one stick; Windows 7 see the Resource Monitor - http://i1013.photobucket.com/albums/af254/Jaquith/RM_7PRO6GB.gif
    Also, 4GB is IMO the minimum for gaming.
    Q - What exact RAM do you have? ; provide a link.
  4. This is the link
    http://www.ebay.com/itm/4GB-KINGSTON-PC3-10600-DDR3-CL9-1333MHZ-ECC-REGISTERED-RAM-P-N-KVR1333D3D4R9S-4G-/251023571538?pt=UK_Computing_ComputerComponents_MemoryRAM_JN&hash=item3a722bba52#ht_1638wt_502
    i know 4gb ram its the minimun to gaming but..the games i play dont need even 2gb of ram..its like play station 1 games and so.. in my older pc i had the same processor, 1gb ddr1 ram..and geforce 5200.. and i could play perfectly with that..so thats why im a little confused about why i cant play if this pc its so much better
  5. Best answer
    Found your problem, the KVR1333D3D4R9S/4G is ECC RAM, but your MOBO only supports non-ECC. Only Intel Xeon can support ECC RAM.
    Therefore, exchange you RAM. :(
  6. aww :( well so thats the problem so i need to change the ram, well thanks :D now i know why the games are not working well lmao :)
  7. Best answer selected by glenn585.
  8. This topic has been closed by Nikorr
Memory Compatibility Processors
