Solved
Help with new build
hi folks,
i need help/compatibility with parts i have chosen.
Approximate Purchase Date:soon. all items r from new egg except ssd from microcenter
Budget Range: $ 2000.00/ After Rebates
System Usage from Most to Least Important: work, gaming, surfing the internet, watching movies
Parts Not Required: keyboard, mouse, monitor, speakers
Preferred Website(s) for Parts: (e.g.: newegg.com & microcenter for parts not available @ newegg.
Country of Origin: USA
Parts Preferences:
COOLER MASTER HAF X RC-942-KKN1 Black Steel/ Plastic ATX Full Tower Computer Case
Item #: N82E16811119225 $189.99
SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Item #: N82E16822152185 $64.99
XFX HD-695X-CNFC Radeon HD 6950 2GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity
Item #: N82E16814150530 $30.00 Mail-in Rebate14-150-530 $274.99
Antec High Current Pro HCP-1200 1200W ATX12V / EPS12V SLI Ready 80 PLUS GOLD Certified Modular Active PFC Power Supply
Item #: N82E16817371043 $299.99
ARCTIC COOLING Arctic Cooling MX-4 AC-MX4 4 gram (g) All-Around Thermal Compound
Item #: N82E16835186038 $14.99
G.SKILL Ripjaws X Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900) Desktop Memory Model F3-14900CL9D-8GBXL
Item #: N82E16820231455 $124.99 Should i get nore?
1 Kingston DataTraveler G3 2GB USB 2.0 Flash Drive (White & Orange) Model DTIG3/2GBZ
Item #: N82E16820139254 -$6.99 Saving $6.99 $0.00
ASUS P8P67 DELUXE (REV 3.0) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Item #: N82E16813131701 $229.99
Intel Core i7-2600K Sandy Bridge 3.4GHz (3.8GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor BX80623I72600K
Item #: N82E16819115070 $314.99
Microsoft Windows 7 Ultimate SP1 64-bit 1-Pack - OEM
Item #: N82E16832116997 $179.99
Scythe SY1225SL12SH 120mm "Slipstream" Case Fan
Item #: N82E16835185060 $17.96 ($8.98 each)
Prolimatech Megahalems Rev.B CPU Cooler
Item #: N82E16835242001 $69.99
1 XIGMATEK PTI-G4512 thermal grease with gold grade thermal matrix filler particles
Item #: N82E16835233069
Return Policy: Standard Return Policy -$9.99 Saving
$9.99
$0.00
LITE-ON Blu-ray Burner with 3D Playback SATA iHBS212 LightScribe
Item #: N82E16827106348 $136.99
1 Verbatim 25GB 2X BD-R LTH Single Jewel Case Disc (use w/LTH Compat Drive) 96569 - OEM
Item #: N82E16817130069
Return Policy: Standard Return Policy -$3.01 Saving
$3.01
$0.00
Subtotal: $1,919.85
ssd ocz vertex 3 - 120 gb @ $ 284.99
Overclocking: Yes
SLI or Crossfire: Yes
Monitor Resolution: 1920x1200
Additional Comments: I would like a quiet PC
thxs for all the help in advance.
9 answers Last reply Best Answer
More about help build
  1. Looks ok, although not sure what your going to do with a 1200w power supply. You got some 18" subs in your computer room or something?
    can u suggest an alternative or if i go crossfire in future is it ok with that power.
  3. For the PSU go for the Seasonic X-750, Superb quality, plenty of power, $130 http://www.newegg.com/Product/Product.aspx?Item=N82E16817151087
    Other than that, drop the Mobo to the Pro version ($175 http://www.newegg.com/Product/Product.aspx?Item=N82E16813131703&cm_re=p8p67_pro-_-13-131-703-_-Product ), and get rid of the MX-4 and you're good to go.
  4. Best answer
    A decent 750w will do just fine for that build, but here's an 850w in case you decide to up grade your vid cards later on down the road and you want some head room.
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.624858 Combo Discount: -$20.00 Combo Price: $209.98 $20.00 Mail-In Rebate Card Price After Mail-In Rebate(s): $189.98
    CORSAIR HX Series CMPSU-850HX 850W ATX12V 2.3 / EPS12V 2.91 80 PLUS SILVER Certified Modular Active PFC Power Supply
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.633398 Combo Discount: -$25.00 Combo Price: $274.98
    ASUS P8P67 PRO (REV 3.0) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
    G.SKILL Sniper Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866 (PC3 14900) Desktop Memory Model F3-14900CL9D-8GBSR
    http://www.amazon.com/Cooler-Master-Advanced-Tower-SuperSpeed/dp/B001EPUQAE/ref=sr_1_6?s=pc&ie=UTF8&qid=1302997743&sr=1-6 $154.82 & this item ships for FREE with Super Saver Shipping
    Cooler Master HAF 932 Advanced Full Tower Case with SuperSpeed USB 3.0 - (RC-932-KKN5-GP)
  5. agree with both of timop's suggestions, except you should get the combo savings:
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.622003
    also looks like youre buying 2 different types of overpriced thermal
    compound.
    edit: as usual why_me wins.
  6. thxs to all i will review and downsize psu. 1 tim is included as a combo deal.
    will the prolima mega fit in the 932?
    Yep. The 932 is a HUGE case. Check the dimensions on that case @ newegg...it's big.
  9. Best answer selected by kburges.
New Build Systems Product
