Next stop for my new build - graphics card. Help?
Below are the parts I have put on the list so far, and I was told to look into a Graphical card next. Budget is between 700-1200, I will not be a heavy gamer, the purpose of the PC is to run multiple OS's at the same time for penetration testing (info security class).
Intel i7 950 3.03GHz
ASUS P6X58D-E LGA 1366 Intel X58 SATA 6Gb/s USB 3.0 ATX Intel Motherboard
Item #: N82E16813131641
CORSAIR DOMINATOR 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Triple Channel Kit Desktop Memory Model TR3X6G1600C8D
Item #: N82E16820145224
Seagate Barracuda XT ST32000641AS 2TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Item #: N82E16822148506
Any help or guidance would be much appreciated!
-adam
2 answers Last reply
More about next stop build graphics card help
  1. I would get something like a 5770. It should fit your needs and exceed them a little. You can pick one up for about $99 after rebate.
  2. I found a bundle deal on newegg for the power supply and this graphics card!
    CORSAIR HX Series CMPSU-650HX 650W ATX12V v2.2 / EPS12V 2.91 SLI Ready 80 PLUS BRONZE Certified Modular Active PFC Power ...
    Item #: N82E16817139012
    ASUS ENGT430/DI/1GD3(LP) GeForce GT 430 (Fermi) 1GB 128-bit DDR3 PCI Express 2.0 x16 HDCP Ready Low Profile Ready Video ...
    Item #: N82E16814121397
Graphics Cards Graphics
