Corsair XMS3 4GB PC10666 DDR3 1333MHz 4096MB - http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6613461
Seagate 1TB LP Serial ATA HD 5900/32MB/SATA-3G - http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4682320
Lite ON 24X DVDRW SATA OEM - http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4829307
Sapphire Radeon HD 5770 1GB PCIe DDR5 DVI / HDMI - http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5660536
AMD Phenom II X4 840 AM3 CPU - http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7225660
ASUS M4N68T-M V2 AM3 NVIDIA Geforce 7025/nForce 630a Micro ATX AMD Motherboard - http://www.newegg.com/Product/Product.aspx?Item=N82E16813131669
Rosewill Blackbone Black Steel / Plastic ATX Mid Tower Computer Case - http://www.newegg.com/Product/Product.aspx?Item=N82E16811147023
Antec EarthWatts EA650 650W Continuous Power ATX12V Ver.2.2 / EPS12V version 2.91 SLI Certified CrossFire Ready 80 PLUS Certified Active PFC "compatible with Core i7/Core i5" Power Supply - http://www.newegg.com/Product/Product.aspx?Item=N82E16817371015
Someone told me to check the RAM, so after fidgeting with that the computer has stopped turning on completely.
What could the problem be?
