Solved
Water Cooling Advice - New/First Build
Last response: in Systems
April 18, 2011 8:39:58 AM
Hello, I've nearly finalized my new gaming build and I am fairly comfortable with it; besides the water cooling. I would greatly appreciate it if somebody could look over my build and specifically answer my questions below.
  • Are all of the water cooling components compatible?
  • Size of the tubing? I imagine that 1/2in ID is fine, but what about the 5/8in OD?
  • How much tubing will I need (ft)?
  • Type and size of barbs fine?
  • How many barbs do I need?
  • If I use compression fittings, then horse clamps aren't needed; correct?
  • Is a tube cutter worth buying, or is a utility knife good enough?
  • Am I missing anything in regards to the water cooling? Even if it is something small and you assume that I just didn't bother mentioning.
    CPU: Intel 2600K
    Case: HAFX 942
    Mobo: Gigabyte UD7
    GPU: 560ti SLI
    PSU: Coolermaster Silent Pro Gold 1000W SLI (Overkill I know, but I would like plenty of extra room)
    RAM: G.SKILL Ripjaws X F3-12800CL8D-8GBXM 8GB 2X4GB DDR3-1600 CL8-8-8-24 1.5V
    HDD: Western Digital Caviar Black 640GB SATA3 6GB/S 7200RPM 64MB Cache x2 (RAID 0 for OS and games - unhappy with SSD options)
    HDD: Western Digital Caviar Black 1TB SATA3 6GB/S 7200RPM 64MB Cache 3.5IN x2 (Storage)
    CPU Waterblock: Swiftech APOGEE XT LGA1366 CPU Water Block G1/4 Chrome HI-FLOW 1/2IN Eurostyle Barb Fittings
    http://www.directcanada.com/products/?sku=14480AC5649&v...
    Pump: Swiftech MCP655 12V Industrial Water Cooling Pump 1/2IN Barbs
    http://www.directcanada.com/products/?sku=14480AC9207&v...
    Rad: Swiftech MCR320 Quiet Power Triple 120MM Water Cooling Radiator Black G1/4 Threaded
    http://www.directcanada.com/products/?sku=14480AC5149&v...
    Res: Swiftech MCRES-MICRO REV2 Clear HI-FLOW Water Cooling Reservoir 3/8IN & 1/2IN Barb Fittings
    http://www.directcanada.com/products/?sku=14480AC6987&v...
    Tubes: Tygon R-3603 1/2" ID 5/8" OD Chemical Tubing (Quantity???)
    http://www.jab-tech.com/Tygon-R-3603-1-2-ID-5-8-OD-Chem...
    Barbs: Dangerden Silver Compression Fitting - 1/2" to 5/8" (Quantity???)
    http://www.jab-tech.com/Dangerden-Silver-Compression-Fi...
    Coolant: Swiftech Hydrx Water Additive Coolant 2 oz Bottle
    http://www.directcanada.com/products/?sku=14480AC2403&v...
    Thermal Paste: ARCTIC COOLING MX-2 Thermal Compound
    http://www.newegg.ca/Product/Product.aspx?Item=N82E1683...
    Price: $2250~
    Thanks!
    Best solution
    April 18, 2011 12:33:25 PM
    Yes
    Needs to match the compression fittings
    Usually 5-8 feet, buy a couple of extra
    You list compression fittings
    A total of 8 fittings, comp. or barb
    Correct
    If you're comfortable with the knife it works fine
    Other than fans, doesn't look like it.
    I 'd skip the Hydrx and just use a silver coil.
    Keep in mind that thin wall tubing tends to kink easier.
    Be sure to drop by the Watercooling section of the forum and let us know how it goes.
    April 18, 2011 1:35:38 PM
    Ah, fans; I actually forgot about those.
    How does these look? The rad says that it is designed for low-medium fans, which I'm guessing is anything below 70~CFM?
    Scythe Slip Stream Kaze Jyuni 120MM Fan 1200RPM 68.5CFM 24DBA
    http://www.directcanada.com/products/?sku=14110AC7800&v...
    Agreed. Is there an ideal amount to use? Should 1 8in strip do the trick? Any idea if it is better to just drop it in the reservoir instead the tubing?
    Without any additives, will I have to worry about corrosion at all?
    I think I'll switch to;
    PrimoFlex Pro LRT UV Green Tubing - 1/2in. ID X 3/4in. OD
    Thanks
    m
    l
    April 18, 2011 2:29:01 PM
    Personally never impressed by the Scythe fans but they should work, I'd go with the 1600 RPM model.
    An 8 inch strip would be plenty, and yes, it's easier to just drop it in the res.
    I use the same tubing in clear.
    m
    l
    April 18, 2011 10:05:20 PM
    A few more questions.
  • My radiator says it has 1/4in threaded hubs. Will 1/2in ID and 3/4in OD compression fittings work fine?
  • I went with Scythe because DirectCanada only carries decent supply of them. Out of those below, which would you recommend? If you feel strongly against them, what would you recommend getting? (From http://www.jab-tech.com/120mm-Fans-c-81.html or http://www.directcanada.com )
    Thermalright Stealth Silent 120MM FDB Case Fan 1600RPM 63.7CFM 28.0DBA
    http://www.directcanada.com/products/?sku=14650AC1692&v...
    Scythe S-FLEX SFF21F 120MM Cooling Fan 1600RPM 28.0DBA 63.7CFM FDB
    http://www.directcanada.com/products/?sku=14110AC5567&v...
    Scythe Kama Flex PWM 120MM Fluid Dynamic Bearing Cooling Fan 300-1600RPM 27.50DBA 63.4CFM by Sony
    http://www.directcanada.com/products/?sku=16950AC2230&v...
    YATE LOON 120x120x20mm Case Fan - D12SM-12C Medium Speed
    http://www.jab-tech.com/YATE-LOON-120x120x20mm-Case-Fan...
  • Is a shroud worth getting? Gaskets?
    Thermochill PS120.3 Shroud for Triple 120MM Fan
    http://www.directcanada.com/products/?sku=23080AC6706&v...
    120mm Anti-Vibration Fan Gasket - Black
    http://www.jab-tech.com/120mm-Anti-Vibration-Fan-Gasket...
    Thanks!
    m
    l
    April 18, 2011 10:51:00 PM
    1- 1/4 is the thread size, 1/2 x 3/4 is the ID and OD of the tubing, will work perfectly
    http://www.jab-tech.com/Enzotechnology-Compression-Fitt...
    2- I'd grab the Yates
    3- Shroud worth it ? Might be, but only minimal gains
    Gaskets ? Mine are still in the box, never tried them ( look down ).
    I have my fans in a box that acts as a shroud when I choose to put it on the rad.
    Something that hasn't been mentioned, do you intend to internally mount the rad ?
    If so , what case ?
    m
    l
    April 18, 2011 11:44:28 PM
    If so , what case ?
    HAF X 942
    http://www.directcanada.com/products/?sku=11130AC7104&v...
    http://www.hardwarecanucks.com/forum/hardware-canucks-r...
    I haven't decided where I plan to mount it yet; probably on the top, internally. Once it arrives I'll have a better idea.
    Here is a list of all of my components.
    http://img716.imageshack.us/img716/407/pcbuild.jpg
    m
    l
    April 18, 2011 11:51:39 PM
    don't buy jab-tech yates they suck the real yates are at petra's tech shop (not sure if they ship to canada)
    m
    l
    April 19, 2011 6:28:48 PM
    If you have the cash go for GT AP 15s or 14s they are out of stock i think at the places you listed but i think aquatuning has them in stock right now or will get them in stock very soon
    m
    l
    April 20, 2011 10:39:17 PM
    if you buy yates jab-techs aren't the ones because they aren't good quality seriously pay like $2 extra per fan and get a 4-pack at petra's for $20
    m
    l
    May 1, 2011 7:45:59 AM
    Best answer selected by RedXIII.
    m
    l
