Ok - So I'm finally getting into the building of a gaming system. This is the first system I've purchased that's designed for gaming rather than just being a powerful system with a half-way decent graphics card. The system seems pretty solid to me and it will be used for the following, in this order:
Warcraft
Internet
Music and such
Nothing major except for Warcraft. Although there are some seriously sick looking games out there, it's Warcraft and whatever my fancy on the PS3 is at the time. I may get into Starcraft, or break out some older C&C or AOE, but Warcraft will be the primary.
I based the build off some of the posts I've read on Tom's Hardware regarding HyperThreading and some of the video cards. Now I wouldn't mind going with a GTX 580 or even the HD 5970...just not willing to shell out another $200-300 just for the video upgrade and I'm really trying to keep it under $1300-1400. I still need a monitor to go with it so I figure that's another couple Hun for a nice one.
Let me know your thoughts please. I appreciate it. Thanks.
BASE_PRICE:[+715]
CAS:* Apevia X-Plorer 2 Mid-Tower Case w/ Side-Panel Window and MultiMeter Display (Silver Color with 200mm UV Blue LED Fan
CD:24X Double Layer Dual Format DVD+-R/+-RW + CD-R/RW Drive (BLACK COLOR)
CPU:Intel® Core™ i5-2500K 3.30 GHz 6M Intel Smart Cache LGA1155 (All Venom OC Certified)
CS_FANefault case fans
FAN:XtremeGear Liquid Cooling System 120MM Radiator & Fan (Enhanced Cooling Performance + Extreme Silent at 20dBA) (Single Standard 120MM Fan)
HDD:64 GB A-DATA S596 Turbo Series Gaming MLC Solid State Disk (Single Hard Drive)
HDD2:500GB SATA-II 3.0Gb/s 16MB Cache 7200RPM HDD (Single Hard Drive)
MEMORY:8GB (2GBx4) DDR3/1600MHz Dual Channel Memory Module (Kingston HyperX
MOTHERBOARD:* [CrossFireX] GigaByte GA-P67A-UD3-B3 Intel P67 Chipset DDR3 ATX Mainboard w/ 7.1 HD Audio, GbLAN, USB3.0, 2x SATA-III RAID, 2 Gen2 PCIe, 3 PCIe X1 & 2 PCI [B3 Stepping]
MULTIVIEW:Non-SLI/Non-CrossFireX Mode Supports Multiple Monitors
NETWORK:Onboard Gigabit LAN Network
OS:Microsoft® Windows® 7 Home Premium (64-bit Edition)
OVERCLOCK:Ultimate OC (Ultimate Overclock 30% or more)
POWERSUPPLY:* 650 Watts - Thermaltake TR2 RX Modular 80 Plus PSU - PN: TRX-650M
SOUND:HIGH DEFINITION ON-BOARD 7.1 AUDIO
USB:Built-in USB 2.0 Ports
VIDEO:NVIDIA GeForce GTX 460 1GB 16X PCIe Video Card (EVGA Superclocked
_PRICE+1297)
And the actual link if you want it - http://www.cyberpowerpc.com/saved/1D69DV
Again - anything advice you can throw out there is apprecaited.
Warcraft
Internet
Music and such
BASE_PRICE:[+715]
_PRICE+1297)
