Hello!
Well, as title says! i have been having some booting problems with my motherboard, well i think is the motherboard, so i need some advice on what to do next!!.
My PC:
Core i7 920 3.6GHz stable.
Gigabyte GA-EX58-UD4P
RAM 6GB
The problem im getting is when i turn off the pc at the night, and want to turn it on next day, it just stays off, when i press chasis power button and mobo power button is the same, the motherboard leds are on, but nothing happens. The psu i think its fine because i use a jumper and everything turns on. so after 5-20 mins or 1 or 2 hrs that i pressed the button turns on, and when windows load, the time and date is wrong and i have to set it again, the battery is fine i checked it with a multimeter and voltage is 3.05v constant without a drop.
It could be a bios problem?? i haven't flashed it because there is no new bios version for that motherboard.
the problem here is that i dont have other cpu or mobo for testing.
so what would i do next???
would i go and buy an used cheap motherboard until 3770k is out????
or what would u do?
Grettings.
My PC:
RAM 6GB
or what would u do?
Grettings.
