my mouse is going crazy, it goes all over the screen and has all the pop up menus going all up.anyone have any idea what it could be.i thought it may have been a virus but scanned pc 2x and it didnt show any virus. last thing i installed was directx 8.1 2 weeks ago and it ran fine. this just started last night,and hope i dont have to reformat...any idea's?
Sponsored Links
Try plugging the mouse into another computer. Perhaps the circuits have been messed up.
Rob
Please visit <b><A HREF="http://www.ncix.com/canada/index.cfm?affiliateid=319048" target="_new">http://www.ncix.com/canada/index.cfm?affiliateid=319048</A></b>
Reply to Arrow
- 0 +
I have a Logitech optical mouse that would not respond properly sometimes after reboot. To get the mouse to respond properly I would have to repeat the reboot.
I never found a valid reason for the instablity which occurred in WinME and WinXP.
After updating to the latest Logitech mouse driver the problem has not reoccurred.
Have you tried reinstalling your mouse driver?
<A HREF="http://www.page3.com/" target="_new"><b>Walter for THGC mascot <font color=red>(·Y·)</font color=red></b></A>
Reply to zpyrd
- 0 +
I had the exact same problem with my mouse a year ago! i bought a new one. What i think the problem was though was that the wires were wearing thin and were picking up some interference, sending the PS2 port incorrect data. Mine started off jumping all over the screen, then it got so bad, that the data the mouse was sending the port made absolutely no sense at all, and brought about a blue screen of death within seconds of Windows completely loading. I got a new mouse, and everything was perfectly fine after that.
So... either do some surgery (may not work), or shell out the dough and get a new mouse! (I recommend MS Intellimouse Explorer - worth the money!!!)
All things must surely have to end...
Functor
Reply to functor
hey, thanks for the help guy's.. it has to be a fualty mouse,i reformated and the problem is still here i thought it was the direct x8.1 .but i know it is the mouse if you shake it around a bit it starts doing all that crazy stuff again..all programs popping up . i'll try to get the intellimouse explorer, does it use track ball or optical..im not really sure if i would go with optical mouse..
Reply to JP_MIGRAINE
The Intellimouse Explorer is optical. Just get an optical mouse. You don't have to worry about dust screwing with the tracking ball. Great stuff... :smile:
Problem solved. Please check out <A HREF="http://www.geocities.com/btvillarin/" target="_new">My Website</A>.
Reply to btvillarin
- 0 +
Looks like you got my post just a fraction too late! Ahh well... The Explorer is optical, and it has4 buttons and a scroll wheel. You might think you wouldnt use these buttins, but after using them for a couple days, you cont live without them. I'm a gamer, and the optical technology rocks! No more cleaning out my mouse every 2 or 3 hours. Go optical! It Rox!
Functor
Reply to functor
you think optical is really better, i thought it might be kinda bugy or somthing. but if you guy's really think it is better i would sure give it a try... thanks again for the help all.
Tom's Hardware > Forum > Windows 95/98/ME > Windows 95/98/Me General Discussion > need help
There are 1294 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
  • 01:00 DustenH won the Uniformed badge
  • 01:00 bew1075k won the Uniformed badge
  • 01:00 Parasitic won the Uniformed badge
  • 01:00 X3no won the Uniformed badge
  • 01:00 Siq won the Uniformed badge
  • 01:00 wayspooled won the Uniformed badge
  • 01:00 chris62 won the Freshman badge
  • 01:00 Tattysnuc won the Freshman badge
  • 01:00 gamerk316 won the Freshman badge
  • 05:23 jsc won the Overclocking badge
