Approximate Purchase Date: With in a month
Budget Range: $1,000 after rebates
System Usage from Most to Least Important: Gaming, coding, programming.
Parts Not Required: Mouse, keyboard, OS
Preferred Website(s) for Parts: newegg.com
Country of Origin: America
Parts Preferences: no refrense really. Usually an AMD/ATI guy but these days it seems Intel is killing AMD.
Overclocking: Minor overclocking. Maybe major as I build my computer skills.
SLI or Crossfire: no
Monitor Resolution: Doesn't matter
Additional Comments: I'm aiming for $1,000 build. I have $50 extra to work with but I'm not sure what I can put that towards to get the most bang for my buck.
LG DVD±RW SuperMulti Drive Black SATA Model GH22NS50 Bulk - OEM $18.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136216
Rosewill CHALLENGER Black Gaming AT...-1x Front Blue LED 120mm Fan, 1x Top 140mm .. $54.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16811147153
Western Digital Caviar Blue WD3200A... 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive $49.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136770
ASUS VH238H Black 23" Full HD HDMI LED Backlight LCD Monitor w/Speakers $179.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236117
ASUS ENGTX460 DC TOP/2DI/1GD5/V2 Ge...press 2.0 x16 HDCP Ready SLI Support Video .. $206.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121420
CORSAIR Enthusiast Series CMPSU-650...dy 80 PLUS Certified Active PFC Compatible .. $89.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005
CORSAIR XMS3 4GB (2 x 2GB) 240-Pin ...Channel Kit Desktop Memory Model TW3X4G1333C9 $45.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145218
ASUS P8H61-M (REV 3.0) LGA 1155 Intel H61 HDMI Micro ATX Intel Motherboard $79.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131716
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
Total is $951
Like I've mentioned before normally I'm an AMD/ATI guy but with the Intel Core i5-2500k Sandy Bridge its seems you'd have to be stupid not to get it. Plus from what I've seen it seems to do well with overclocking. From what I could research and tell it seems that everything works with each other and is the most bang for my buck but I'm sure I overlooked something. And with getting Intel processor and Intel MOBO is it even worth looking for and ATI card. At the mid range cards for around $200 I kept finding mixed reviews of the cards in that range. So any help there would be very much welcomed and appreciated.
Total is $951
