Yesterday I was on my pc for a few hours playing games then stopped when I came back to my pc and started it up it booted then 2 mins later it BSOD'd which was annoying as my ram is pretty new.
So I took out each stick and tested each one it turned out that 3 sticks where "bad" so I used the one to just have my pc going then after a few hours another stick went so I decided to test them all again.
After the second check 2 where bad and 2 were good but if I use the 2 good ones together it would BSOD so would this be a ram or board problem ?
My System
MSI P55 GD85 mobo
Intel Core I5 3.2GHz: Akasa NeroS cooler
Corsair TX650
Gigabyte ATI HD 5850
WD Black 1TB
NZXT Phantom Red+Black custom case
2x Corsair 2GB + 2x Kingston Valueram 2GB
I can't tell which sticks are bad as they keep working then not working
My System
MSI P55 GD85 mobo
Corsair TX650
WD Black 1TB
