Hi guys. I built a new PC a few months ago and now that i am coming to overclocking i am finding that my temps seem a lot higher than most people with a similar setup. My setup is as follows:
Intel Core i5 760 @ Stock
Coolermaster Hyper 212+ (Push/Pull with supplied Cooler Master fan and a 120mm Zalman 'Golf' fan)
Antec Nine Hundred Two (No side fan as it wont fit with the CPU cooler)
Palit GTX 460 1GB (Stock Cooler, Stock Clock)
XFX PRO750W (Pointed with the fan upwards.)
The rest of my build is in my signature, this is the important stuff.
With all my fans on low settings, my GPU hits 92c on a stress test. My CPU hits 60c
With all my fans as loud as i find bearable (usual) my GPU hits 77c and my CPU hits 57c (Also on auto where fans go faster the hotter it gets.)
With all my fans full on my GPU hits 68c and my CPU hits 56c. (And my ears bleed)
The fans on my case are as follows:
Top - 200mm - Exhaust (Usually full on)
Rear - 120mm - Exhaust (Usually on low)
Front x 2 - 120mm - Intake (Usually on Halfway)
I don't know about anyone else, but these temps seem unusually high to me. Does anyone have any tips on reducing them? Does this seem like it might be a good solution for the GPU at least? Thanks for any help i may receive
