Solved
A Power Supply Fault?
I am building a system, using the following components
GA-H55M-USB3 Motherboard
Intel i3-540 LGA1156 Processor
Patriot Signature 4gb Ddr3 1333 Cl9 D/C Memory
OCZ StealthXStream 2 500W Power Supply
Nothing else is attached at this stag except for the standard fan that came with the CPU, which is connected to the CPU fan connector. The power switch is the only front panel connection.
I am having difficulty getting it to power up.
If I connect the ATX power cable and the ATX_12X_2X4 (the 8 pin), nothing happens, not even a flicker of fan, light or screen
If I connect the ATX power cable and the 4 pin power connector labelled P3 on the socket it powers up and goes to the bios and then looks for an OS.
Is this a problem with the Power Supply or is there another solution/is it a problem?
At the moment the machine is has no storage or optical drives, when in use it will have a small SSD and a couple of 2TB and will be build as a Vortexbox (a Linux distro).
5 answers Last reply Best Answer
More about power supply fault
  1. Best answer
    MikeBOSoft said:
    If I connect the ATX power cable and the ATX_12X_2X4 (the 8 pin), nothing happens, not even a flicker of fan, light or screenIf I connect the ATX power cable and the 4 pin power connector labelled P3 on the socket it powers up and goes to the bios and then looks for an OS.
    Is this a problem with the Power Supply or is there another solution/is it a problem ?
    Considering the fact that the SXSII 500 doesn't have an 8 pin EPS connector ( or 4+4, or 2x4 ) I'd say it was a problem, just not neccessarily with the psu.
  2. Thanks, I have just discovered my mistake, I was using the PCI-E connector, which fits into the connection - all the pin shapes are correct, but obviously isn't right.
    One thing that confused me was that the box has been modified with a sticky label that says
    4 pin CPU; 1 x 4-8 adapter.
    Thanks again.
  3. No there wasn't though it was an E-bay acquisition.
  4. Best answer selected by MikeBOSoft.
Homebuilt Systems Product
