Hello, I have an older hp that has only one x16 slot and I'm trying to install a gts450. Problem is it's a 2 bay card and the x16 slot is at the top so the fan port doesn't have anywhere to go. It will fit fine in the x4 slot, the fan/heat sink then covers the x16 slot, which is fine but obviously I can't use that slot. Anybody know of an adaptor or some kind of fix?
Thanks,
Hank
Thanks,
Hank
