Greetings,
I just bought Samsung SyncMaster P2770HD. I am using a laptop, ACER 5942G with ATI5650 Graphic Card.
The problem is when connecting monitor using the HDMI port.
The picture quality is not so good when on 1920x1080 resolution. The quality is ok when using 1680x1050 resolution.
VGA output works perfectly on all resolutions, but its funny I cant normally use HDMI. I was wondering if someone had a similar problem, or a solution.
Thanks in advanced for your help.
PS.
Its also interesting that while i was creating screenshots of both resolutions.. they appear to look the same although they are not. A monitor problem?
https://picasaweb.google.com/sapa0604/SAMSUNGALBUM#
PS.
