Closed Solved
Help finding a MOBO upgrade!
Board: ASRock N68PV-GS
Bus Clock: 200 megahertz
BIOS: American Megatrends Inc. P1.30 01/08/2009
This is my current MOBO, looking for something that supports newer ram, so I can buy cheaper RAM.
Looking for the cheapest, most efficient upgrade. My intention is to upgrade to 8gigs of RAM.
I need something with the AM3 socket where I know that my Processor will be compatible.
3.00 gigahertz AMD Phenom II X4 945
512 kilobyte primary memory cache
2048 kilobyte secondary memory cache
64-bit ready
Multi-core (4 total)
Not hyper-threaded
*If there is a way I can get 8gbs of ram on my PC without upgrading the MOBO without spending over 100$ please feel free to help =)! Thanks!
3 answers Last reply Best Answer
More about help finding mobo upgrade
  1. Best answer
    Here is a good inexpensive MB that supports you cpu.
    MSI 870A-G46 AM3 AMD 870 SATA 6Gb/s USB 3.0 ATX AMD Motherboard
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813130591
  2. Best answer selected by tmt69.
  3. This topic has been closed by Nikorr
Motherboards RAM Product
