Graphics Instability.. I think? Help.
Hello all, I have been experiencing some issues on a new system I built. Everything posts fine, bootup is fast with no problems, windows runs fine... system will pass prime 95 for 10 hours and Intel Burn Test 10 cycles with no errors/crashes and keeping processor temps below 65C. However whenever I play a graphically demanding game... Crysis/Civ 5/BFBC2 after about 10-15 minutes the games go to a black screen and do not recover, however I am able to ctr-alt-del and end the programs manually after which my system returns to windows without issue. The following are my system specs:
intel i5 2500k (was running at 4.5ghz but have reduced it to stock to troubleshoot this issue)
Asus P67 Sabertooth motherboard
8gigs G.skill ripjaw at 1600mhz
WD Caviar Black 1TB HD
2x EVGA GTX 460 FTW EE in SLI (using most recent nvidia drivers)
24x dvd-rw
Coolermaster 690 Case
Corsair 750HX PSU
Corsair H70 CPU cooling system
Windows 7 64 bit
My case has 1 front mounted 120mm intake fan, 1 120mm top intake fan (mounted all the way at the front of the case blowing air down the drives) 1 120mm side intake fan blowing cool air directly on the GTX 460's. For exhaust the case has the Corsair H70 with 2x120mm fans in push pull config as well as the dual gtx460's which are external exhaust.
I can't figure out what the problem is, please help!
1 answer Last reply
More about graphics instability think help
  1. This screams hardware failure.
    Likely Culprits:
    PSU
    Bad Memory
    Bad Video Memory
    To troubleshoot, disable SLI, remove one of the cards. Test the games for a significant amount of time. Replace the card with the other card. Retest
    If you crash only one 1 card, this will likely mean the crashing card is bad, in some fashion,.
    If you crash both cards individually, you might have bad system memory, run memtest 86+ as recommended.
    If you crash neither card, your PSU is likely choking under load, get a testing kit and test the PSU. Also, ensure your SLI bridge is secure.
    Edit: This is by no way and end-all way of troubleshooting, but will likely help you diagnose the problem in the most likely places for failure. Ultimately a driver failure could cause this, aswell, but is simply 100X less likely than the above.
Graphics Cards Graphics
