Solved
5870 read as a 5400 series problem
  • Graphics Cards
  • Graphics
February 16, 2011 9:10:19 AM
Hey Everyone,
I need help with a problem i've had on my computer for about a year now. All my programs read my graphics card as from the 5400 series graphics card and the driver as a 5800 series driver. My graphics card is a Gigabyte HD 5870 SOC edition. The only program that recognises the card is GPU-z. Here is what steam system information reads:
Processor Information:
Vendor: AuthenticAMD
Speed: 3415 Mhz
4 logical processors
4 physical processors
HyperThreading: Unsupported
FCMOV: Supported
SSE2: Supported
SSE3: Supported
SSSE3: Supported
SSE4a: Supported
SSE41: Unsupported
SSE42: Unsupported
Network Information:
Network Speed:
Operating System Version:
Windows 7 (64 bit)
NTFS: Supported
Crypto Provider Codes: Supported 323 0x0 0x0 0x0
Video Card:
Driver: ATI Radeon HD 5800 Series
DirectX Driver Name: aticfx32.dll
Driver Version: 8.771.0.0
DirectX Driver Version: 8.17.10.1043
Driver Date: 25 Aug 2010
Desktop Color Depth: 32 bits per pixel
Monitor Refresh Rate: 60 Hz
DirectX Card: ATI Radeon HD 5400 Series
VendorID: 0x1002
DeviceID: 0x6898
Number of Monitors: 1
Number of Logical Video Cards: 1
No SLI or Crossfire Detected
Primary Display Resolution: 1920 x 1080
Desktop Resolution: 1920 x 1080
Primary Display Size: 26.65" x 15.00" (30.55" diag)
67.7cm x 38.1cm (77.6cm diag)
Primary Bus Type Not Detected
Primary VRAM: 1024 MB
Supported MSAA Modes: 2x 4x 8x
Sound card:
Audio device: Speakers (VIA High Definition A
Memory:
RAM: 4095 Mb
Miscellaneous:
UI Language: English
Microphone: Not set
Media Type: DVD
Total Hard Disk Space Available: 953766 Mb
Largest Free Hard Disk Block: 601360 Mb
Steam Hard Disk Usage: 19034 Mb
OS Install Date: Jul 22 2010
Game Controller: None detected
I have a feeling this is the result of some of my games running strangely and occasionally crashing (far cry 2, modern warfare 2, etc.).
any feedback would be greatly appreciated.
Cheers,
Jesse
More about : 5870 read 5400 series problem
Best solution
a b U Graphics card
February 16, 2011 9:23:43 AM
5400 Series is the family of card and is a misnomer.
Basically it should say 5000 series, but some software will call it a 5400 series simply because no card was made lower than 5400 (specifically 5450, I beleive).
Basically any card that is 5XXX is in the 5000/5400 Series and share a common GPU (possibly different versions of the same GPU processor) Evergreen, from what I looked up.
Your card is being recognized correctly, it's just that some software might call it by the wrong name (5400), as I believe AMD refers to it as the 5000 or 5XXX series.
If you're having trouble, from the looks of your Steam Readout, your drivers are fairly out of date and probably need to be updated via AMD.com.
February 16, 2011 9:35:13 AM
Thanks for the quick reply mirrion,
Pretty much all my games read the card as a 5400 and I started to worry. Anyway now I know all is ok i'll do a driver update.
m
l
a b U Graphics card
February 16, 2011 2:03:48 PM
Hmm....I have no idea what the problem could be. lol
m
l
March 3, 2011 4:33:35 AM
Best answer selected by buchananjesse.
m
l
