FIXED WEBSITE LINKS, NOW YOU CAN SEE
well I build a new PC gaming for the first time, budget in 1500 but I spent less...
here is my new build,
CPU - http://www.newegg.com/Product/Product.aspx?Item=N82E16819115073
MotherBoard- http://www.newegg.com/Product/Product.aspx?Item=N82E16813128478
Memory - http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-RSSDailyDeals-_-na-_-na&AID=10521304&PID=4176827&SID=1eqq6sb2ebhkf
Case- http://www.newegg.com/Product/Product.aspx?Item=N82E16811133099&Tpk=v5%20black%20edition&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-RSSDailyDeals-_-na-_-na&AID=10521304&PID=4176827&SID=1iysiwwyuimgt
HardDrive- http://www.newegg.com/Product/Product.aspx?Item=N82E16822152185
2x this Video Card- http://www.newegg.com/Product/Product.aspx?Item=N82E16814125334
Power supply-http://www.newegg.com/Product/Product.aspx?Item=N82E16817151095&cm_re=seasonic_620w-_-17-151-095-_-Product&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-RSSDailyDeals-_-na-_-na&AID=10521304&PID=4176827&SID=ljtk86dolbqg
CD-rom - http://www.newegg.com/Product/Product.aspx?Item=N82E16827151175
all of it costs 1042 USdollars
will it work?...
ohh and btw, what other parts u recommend me to improve?
and what games does this Build will run? will it run CRYSIS 2, BFBC2, metro2033 on Maximun without lags?
EDIT!!!
I fixed the links
will it work?...
EDIT!!!
I fixed the links
