Help fix any issues with my build?
Hey, looking to build a budget PC that i can upgrade later on, and so far, this is what I've gathered based on what I've heard/read from other posts and my earlier post.
I want a decent computer, for around $600-$750, that can play games like WoW and Rift on highish settings, as that's all i really play, and with 30-40+ fps.
Here's what i got so far:
G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory - 49.99
SAPPHIRE 100283-3L Radeon HD 5770 1GB 128-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card - 114.99
NZXT GAMMA Classic Series GAMA-001BK Black Steel ATX Mid Tower Computer Case - 39.99
XIGMATEK ACXTNRP-PC402 400W ATX12V Ver.2.3 80 PLUS BRONZE Certified Active PFC Power Supply - 39.95
Microsoft Windows 7 Home Premium 64-bit 1-Pack for System Builders - 94.99
LITE-ON CD/DVD Burner - Bulk Black SATA Model iHAS124-04 - 19.99
SAMSUNG Spinpoint F3 HD502HJ 500GB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive - 49.99
MSI NF750-G55 AM3 NVIDIA nForce 750a SLI HDMI ATX AMD Motherboard
AMD Phenom II X2 555 Black Edition Callisto 3.2GHz Socket AM3 80W Dual-Core Desktop Processor - C3 Revision HDZ555WFGMBOX - Combo: 181.98
Total: $591.87 after rebates
Will be purchasing a mouse and Key-board later, so that'll be added to the cost at some point.
What you think? Anything i can improve or change, but still have enough for a decent mouse/keyboard?
6 answers Last reply
More about help issues build
  1. Hello bbarrington42;
    What resolution is your monitor?
    You have an nForce 750a SLI motherboard but a HD 5770 Crossfire graphics card. That's a potential mis-match for upgrading.
    And your 400W PSU is nicely matched to your current system but could require replacing most future upgrade scenarios.
  2. overal its pretty good, a few suggested changes though
    Athlon II X3 450: $79.99
    AS Rock 880GM: $59.99
    not a combo, but the 3 core processor is better, and you save $41 off your combo.
    Get 4 Gb of just regular G.skill DDR3-1333 (10666) RAM: $39.99 and the Seagate 500 GB drive for $39.99, and thats another $20 saved. Combined with the other saving and you can afford a $169.99 HD 6850, a better card than the 5770.
    Pick up a mouse/keyboard on the cheap. (I think theres a Pixxo combo of mouse, keyboard and 2 speakers for $17)
  3. if you want to get the cheapest possible computer that will play those 2 games, thats one thing. but IMO, why would you spend $600 of your money for a crappy computer when $720 (inside your budget) will get you an awesome one with a modern socket? If you really need to save money, see if you live near a microcenter. You can save $30 on the processor (including tax) and $10-$20 on the case there.
    LG DVD Burner Black SATA Model GH24NS70 - OEM
    Item #: N82E16827136236
    Return Policy: Standard Return Policy
    Protect Your Investment (expand for options)
    $20.99
    Item #: N82E16811146061
    -$10.00 Instant
    $49.99
    $39.99
    Item #: N82E16822152181
    $49.99
    SAPPHIRE 100282XTREME Radeon HD 5850 Xtreme 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready CrossFireX Support Video Card ...
    Item #: N82E16814102932
    Return Policy: VGA Standard Return Policy
    $139.99
    Antec BP550 Plus 550W Continuous Power ATX12V V2.2 80 PLUS Certified Modular Active PFC Power Supply
    Item #: N82E16817371016
    -$20.00 Instant
    $79.99
    $59.99
    G.SKILL Ripjaws Series 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10666) Desktop Memory Model F3-10666CL9D-4GBRL
    Item #: N82E16820231274
    Return Policy: Memory Standard Return Policy
    $44.99
    Microsoft Windows 7 Home Premium 64-bit 1-Pack for System Builders - OEM
    Item #: N82E16832116754
    Return Policy: Software Standard Return Policy
    -$5.00 Instant
    $99.99
    $94.99
    Intel Core i5-2400 Sandy Bridge 3.1GHz (3.4GHz Turbo Boost) LGA 1155 95W Quad-Core Desktop Processor BX80623I52400
    Item #: N82E16819115074
    Return Policy: CPU Replacement Only Return Policy
    ASUS P8H61-M LE/CSM (REV 3.0) LGA 1155 Intel H61 Micro ATX Intel Motherboard
    Item #: N82E16813131724
    -$20.00 Combo
    $269.98
    $249.98
    Subtotal: $700.91
    Calculate Shipping
    Zip Code: GO
    FREE 2-Day Shipping learn more
    Shipping: $19.01
    Redeem Newegg Gift Cards
    Card Number: Security Code: Apply
    Apply Promo Codes
    Stacking is not permitted. If multiple codes are entered for the same item, only the first promo code will apply.
    Enter Promo Code: AddFind codes in our current e-mail promotion.
    Although you've entered a valid promo code PSU11APRIL, your order does not currently meet the code's usage criteria.
    Although you've entered a valid promo code EMCKFHJ22, your order does not currently meet the code's usage criteria.
    Remove EMCKFHH39 Free ShippingCharge From Promo Code -$2.25
    No Interest if paid in full in up to 12 Months. Minimum purchase required.
    Subject to credit approval. See Terms
    Grand Total: $717.67
  4. I'm OK with your CPU choice or ScrewySqrl's suggested Athlon II X3 450.
    But if you're serious about keeping your upgrade options open you want to think about an AM3+ motherboard;
    ASRock 880G PRO3 Motherboard AM3+ black socket $100
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813157243
  5. Thanks for all the advice, i'll keep that in mind and welcome any new advice you can offer. I'll look into getting a better mobo and keeping my options open. The i5 build looks alot better than my current build, so i'll look into that. Thanks, and keep the replies rolling in, incase theres anything i missed.
Homebuilt Systems Product
