G Gage Ibbetson Distinguished Feb 12, 2011 30 0 18,530 Feb 17, 2011 #1 Will this http://www.newegg.com/Product/Product.aspx?Item=N82E16814103085&cm_re=5850-_-14-103-085-_-Product Fit in this http://www.newegg.com/Product/Product.aspx?Item=N82E16811147153 ?
purple stain Splendid Nov 2, 2010 6,941 7 26,465 Feb 17, 2011 #2 Yes it will fit it fine. Upvote 0 Downvote
Griffolion Distinguished May 28, 2009 1,806 0 19,960 Feb 17, 2011 #3 Judging from the dimensions and the user manual, i think you'll be okay. Upvote 0 Downvote
geekapproved Splendid Dec 10, 2010 8,766 0 31,460 Feb 17, 2011 #4 Id recommend this for cheaper. http://www.newegg.com/Product/Product.aspx?Item=N82E16814161349&cm_re=6870-_-14-161-349-_-Product $185 after rebate and $10 gift card + $8 shipping makes it cheaper. HD5850 is 9.5inches. The HD6870 is 9.84inches. Upvote 0 Downvote
