I'm putting together a new system and have been able to answer most of my questions just going through the archive of articles here. I'm currently (subject to change) thinking of an i5-2500k with a Gigabyte Ga-Z68AP-D3 mobo. I had a few questions about Ram memory. Intel's web site states that the 2500k, which is relatively new, lists compatible ram memory as DDR3-1066/1333. I couldn't believe 1666 wasn't on the list.The mobo lists all speeds from 1066-2133. After reading Bilbats comments about latency, I'm now on the hunt for CL7 (or lower) ram. I'm assuming I'll get 1333. My mother board specs said it supported dual channel ram. In theory, it has another communication/transportation channel and will be twice as fast as just having one. I'm trying to understand how it works, especially with 4 memory banks.
Question: Exactly when am I using the extra channel?
With dual channel boards they color the banks in two different colors. Banks A and C will be one color and B and D will be another color. When you install your first Dimm kit, you are supposed to put them in banks A and C. If you get more later they go into B and D.
Questions: Does this mean one channel is actually A&B and the other B&C? The store I am buying my memory from lists over 200 types of memory and only one says dual channel. Is this an old or new technology?
Any help would be appreciated.
