Hello,
I have a windows xp sp3 pc with a ATI radeon x1050 graphics cart.
I have recently bought a 24" monitor, but now I wanted to connect my old 19" monitor as a second monitor.
So I connected the screen to DVI port using a DVI to VGA connector, but I couldn't set the second screen as an extended desktop. I'm sure the screen is connected properly and is working, because when I lower the resolution of my primary monitor to the resolution of my secondary monitor the screen works fine, but it is just a copy of the primary screen, not an extended desktop.
What I have tried allready:
* using catalyst -> I can click the second screen and it then prompts me, asking if I wish to activate the second screen, when I click yes, it doesn't activate the screen.
* Using windows desktop properties -> I click the option to extend my desktop, but when I click "apply" the option is automatically deactivated.
* I have uninstalled the ATI drivers and tried with the default windows drivers, but that didn't work.
* I have installed the latest drivers, but still the same problem.
I don't know what to do?
Could it be that the resolution is too high for my graphics cart with two screens (1920x1080 + 1280x1024).
Would it work with a DVI + VGA cable in stead of using 2 VGA cables and a DVI to VGA adaptor?
I don't have a DVI cable and don't want to pay 25€ for something that might not even solves my problem.
Did anybody knows something that I can try?
thx allready!
thx allready!
