Yes No
Ads
Tom's Hardware > Forum > CPU & Components > Power Supplies, Cases & Mods > [Solved] Front Panel Cable Connectors Too Tall for Graphics Card!
Forum CPU & Components : Power Supplies, Cases & Mods [Solved] Front Panel Cable Connectors Too Tall for Graphics Card!
Best answer from motopsychojdn.
I am using the following components:
GIGABYTE GA-880GA-UD3H AM3 AMD 880G SATA 6Gb/s USB 3.0 HDMI ATX AMD Motherboard
http://www.newegg.com/Product/Prod [...] 6813128444
LIAN LI PC-A71F Black Aluminum ATX Full Tower Computer Case
http://www.newegg.com/Product/Prod [...] 6811112244
XFX HD-687A-ZDFC Radeon HD 6870 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card with Eyefinity
http://www.newegg.com/Product/Prod [...] 6814150521
I am trying to install the XFX graphics card into the bottom PCIe slot (the top one will also have an XFX, for Crossfire)
Unfortunately the system control pins (PWR, RST, HDD LED, PWR LED, etc) are directly in line with the PCIe slot, and the XFX is long enough that it sits on top of these control pins
See the picture here:
http://samjlevy.com/files/xfx.jpg
You can see the black corner of the graphics card pushing down on the connectors-- it cannot seat correctly. If I do not have the connectors present, the graphics card will seat correctly.
It basically comes down to the fact (other than Gigabyte's strange placement) that the Lian Li's front panel connectors are too tall. Has anyone ever heard of a low-profile front cable connector adapter? Or could I simply cut the connectors so that they are shorter, therefore giving my graphics card enough clearance?
I am a little shocked that Gigabyte would design a Crossfire board -- knowing of larger graphics cards-- and put the power connectors directly in line with the PCIe slot.........
Any suggestions would be greatly appreciated
Thank you
Reply to samJL
Best answer
You could trim them down with a sharp knife and/or bend the wires 90'
Extenders may or may not have smaller plugs, I think they're pretty much a standard size http://pcpartsandcables.com//produ [...] a2109c4868
Personally, I'd label up the fp cables (somewhere further down the cable so as to be out of sight), remove the blocks and connect them straight to the pins
Moto
------------------------------ Once you start watercooling, you are almost automatically inducted into the modding circles as well, because theres rarely a 'from the box, fits everyone' solution, its your ingenuity and resourcefulness that makes it all happen,
Reply to motopsychojdn
+1
Then a dab of hot glue , just to make sure they stay.
Reply to delluser1
IMHO, it's a toss up who's at fault here. I would notify both the MB & GPU OEMs but they will probably blame each other. Personally, I wouldn't blame the box maker for this. I STRONGLY discourage gluing wires to your MB. If this were mine I would try returning one or both items in favor of some I had researched better. If you're stuck with the components try modifying the corner of the fan shroud just enough to clear and then covering any air escape paths with tape if necessary. I'd use aluminum tape but others would work. Good luck.
Reply to ram1009
Thanks for your answers
I have a few options to look at now
Reply to samJL
So you wouldn't reccomend a non destructive mod;
Hot melt glue; not hot enough to damage the board or connector, strong enough to keeep the pins from being inadvertently knocked around, and removes without leaving a trace
But you would reccomend physically damaging the card, most likely voiding it's warranty, and throwing some metal tape into the mix :o
PS;
No one's at fault, try as they might they just can't make sure that all parts are compatible all of the time.
Reply to delluser1
^Aluminium is conductive Dell but I share your opinion on other grounds,
rather chop/remove a 2p connector than slice up a $$$/£££ graphics card shroud :P
if you have to destroy something out of necessity, make it the cheapest component
hehe
I dont glue pins myself but I also dont see the harm in a little extra security
and yes, its no-ones 'fault' its just a small thing Op has to workaround, happens all the time on builds as I'm sure you know :)
Moto
Thank you for B.a. man,
post some pics of the fix if you got them? :)
Moto
Moto
Sure
I am holding off on the Xfire until the HD series 7 is released
I am planning on using extenders-- taking the boxes off of those and folding the wires
That way I don't risk damaging the Lian Li's cable, nor will i need to label the cables
It's also possible that the series 7 will clear the pins enough that it won't be a problem
Reply to samJL
This topic has been closed by Mousemonkey
------------------------------ http://img545.imageshack.us/img545/3995/bl11.gif
Reply to Mousemonkey
There are 1890 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
3930k idles low, boots hot, then cools?
By DJDeCiBeL, 4 hours ago:
Check your temps with HWMonitor, Core Temp or RealTemp. SpeedFan seems to be wrong more...
Best offers
Top experts
