Dg41rq motherboard green chip heat problem
Dear Sir/Mam
I have a intel DG41RQ series motherboard. When i on the pc then i'm faccing green chip heating problem. But the system restart in every 30 minuts. Dear sir i hopr u my problem as soon as possible.
Thanks and Regards
Inderpal Singh
Mob +91-8750171753
2 answers Last reply
More about dg41rq motherboard green chip heat problem
  1. Can you explain what you mean by green chip? If you look at a picture at http://www.tigerdirect.ca/applications/SearchTools/item-details.asp?EdpNo=534854&CatId=1572, could you identify which chip is getting too hot? Does your system have good airflow and what is the ambient temperature of the room?
  2. Yes I am also very confused as to what you are asking for. Inderpal you can contact our Technical support for your by finding the contact information at this site http://www.intel.com/p/en_US/support/contact/phone .
    Christian Wood
    Intel Enthusiast Team
Motherboards Chip Green
