Closed Solved
Help me buying a 5.1 speaker system
Hai.. want to buy a new 5.1 home theatre for my computer.
couplle of things want to know before buying...
1. Creative/Logitech.. (planning to buy t6100..undecided)
2. I already have sbs A300 (2.1) speaker system from creative.
want to connect both the speakers... how do i configure combining 2.1 & 5.1 systems in 1 computer??
3. Want to fit it with my room.. extending wires ?? how ??
Sorry for bad english...
Help !!
11 answers Last reply Best Answer
More about help buying speaker system
  1. Anyone ?? please ........
  2. I have a older set of 5.1 Logitech speaker and they are great. The surrounds have kinda long wires so I am not sure if you need to extend them. I put my surrounds on the sides aiming in they are not super load so I would not space them real far away as you won't hear them very well. I am sure you can longer wires from Radio shack or online.
  3. Best answer
    use a 3.5mm for for the speakers taht are going to share the same channel.
    so for example use 3.5mm for the green jack, for the front and left of the 2.1 and the 5.1
    yoou only need to think a little about this, before you realize how simple it actually is.
  4. Why don't you have a look at a EDIFIER R501
    http://www.edifier.com/eng2005/product/s0033_00.htm
    Not available mate
    Can u post an image to explain it to me.. ?
  7. lol no image, its only my suggestion that i know will work, and i believe no one has done it, but trust me, when u figure it out, you will kno what i mean..
  8. RCA Copper plated cable ??
  9. Best answer selected by Heart beats.
  10. Thanks megamer... it worked !!! thanks a lot !
  11. This topic has been closed by Mousemonkey
Sound Cards Speakers Computers Creative Components
