Weirdes Problem Ever - Sound
Last response: in Components
Hey guys, how are ya'll?
Well, a week ago I went out of home for a little vacation. When I left, my computer was absolutely fine, up and running.
When I came back I realized I have no sound (I have an OnBoard sound chip, Realtek HD Audio Manager, 6 different color jacks).
Automatically, I checked the connections but everything was in place. Restarted. Then the audio manager started to freak out - told me that I unplugged a device then replugged without stopping. funniest thing is that the manager shows that devices are connected to certain color jack whilst they are connected to different color jacks (i.e. my speakers currently connected to the green jack but the manager shows they're connected to the black one, which honestly, I have no clue what it is used for...).
Of course I don't have to mention that I'm not touching the connections. SO I reinstalled the drivers, the manager mobo's drivers. Tried closing the manager's process and try using Windows' drivers but nothing worked. Forgot to mention I saw a BSOD once.
My guess is that the sound chip is dead? In that case, does it mean a new mobo?
If you'll have a solution I'll be the most thankful guy ever.
Thanks in advance.
More about : weirdes problem sound
even if your sound chip was dead you wouldnt have to replace the motherboard--you could just add a pci sound card and disable onboard sound in the bios--cheaper and easier than a new motherboard
Related ressources
mcnumpty23 said:
have you tried uninstalling and re-installing sound drivers? and restoring it to when the sound worked if you have system restore turned on?
yes, tried all these.. Nothing worked.
yeah--tried to edit the driver question but it wont let me edit for some reason
do you have a spare hard drive and the means to do a clean install on it? --if it works on clean install then its a software problem
well, no >.<
Do you know a way to make sure whether it is a hardware problem or a software problem aside of a clean install?
OK, calm down people.
The BSOD is the most worrying problem, as that indicates a HW fault. And its VERY unlikey the soundboard on the mobo itself decided to fry. I'd wager bad memory, as it can cause the type of behavior you are seeing. Before doing anything else, run a scan with memtest86 to make sure you didn't lose a stick of RAM.
Seriously, a clean install should always be the LAST option, not the first...
ok going for this one now.
thanks for the reply
Ask the community
