Yes No
Ads
Tom's Hardware > Forum > CPU & Components > Sound Cards > Recommendation for Sound Card
Forum CPU & Components : Sound Cards Recommendation for Sound Card
Too much struggle. Just to play Black Ops with no stutter on my 4.5 year old dell.
Today, I disabled my sound card and tried playing Black Ops.
The STUTTERING IS GONE!!!
People told me I needed to change to 16 bit, 40000KHz? Hz? GHz? or something I don't know.
Though I still play in the 30's and up fps, the game is SO MUCH SMOOTHER!!
anyway. playing with no sound is still boring.
Just to fix the stupid stutter, I was thinking about buying a whole new computer, but I guess I'll just stick with replacing a sound card.
For Black Ops people out there, pleaese tell me what bit and hertz I need to set my sound card to in order to play black ops fine.
Also, I need to buy a new sound card since mine is Sigmatel (what the crap is this?)
Please recommend a sound card that won't cause ANY stuttering on Black Ops.
Thx
Reply to reqhjack24
I Recommend getting this sound card... It's like the most popular right now...
http://www.ascendtech.us/itemdesc. [...] 660AUDG4SB
Reply to LegendKiller
^^Uhh...no. Totally obsolete. For a cheap option, I recommend the ASUS Xonar DS. [The DX is more capable, but I wouldn't sink too much money into such an old PC]
Odds are, one of two things are causing your PC to slow down:
1: Bad soundcard drivers
2: Weak CPU
In any case, getting a soundcard will NOT help if its the 2nd, because sound isn't HW accelerated. So it won't help any. System specs would help a bit...
Reply to gamerk316
well. i've already decided NOT to upgrade anything else because of my budget.
i DO have a low fps. but its playable without sound. however, i want to keep this gameplay WITH sound so i thought about upgrading my sound card.
any card recommended for Black Ops? i heard black ops had some issues with sound cards as well.
P.S. i can only get to best buy. no where else. no online.
Reply to reqhjack24
I haven't ever heard of your onboard sound card or any for that matter causing game stutters. There must be another problem.. what cpu do you have in your Dell.
Reply to christop
There are 1888 identified and unidentified users. To see the list of identified users, Click here.
Ads
Latest best answer
3930k idles low, boots hot, then cools?
By DJDeCiBeL, 4 hours ago:
Check your temps with HWMonitor, Core Temp or RealTemp. SpeedFan seems to be wrong more...
Best offers
Top experts
