Hello dear friends..
I built a new system ( a week older ). The specs are :
1. Asus P8P67 Pro ---- Intel Core i7 2600K ---- HD 6950 2GB ----- Cooler Master Hyper 212+ Cooler --- Tuniq TX-3 Thermal Paste ---- Corsair TX750W PSU ---- GSkill 4 x 2 GB Sandy Bridge RAM @ Dimm 2 and 4 (9-9-9-24) @ 1600MHz ---- Win 7 Ultimate Original 64 bit
My problems are :
1. At idle, CPU temp is around 35-41 Celsius. But at load it goes up to 56-60 celsius @ 3.4GHz ( factory speed ). Is this normal?
2.I use ASUS's Software which came with MOBO called Auto tune. So i used it to overclock ( just a press of button ). The problems are :
I:
a. Speed @ 4.3GHz ---- When restarting or booting normally, the system starts for 3-4 seconds, shuts down immediately and again restarts again. This happens even with a overclock through bios feature ( EFI Bios - When using Performance mode - ASUS owners know this probably). Is this normal?
b. Speed @ 4.3GHz ---- The temperature is around 45Celsius idle and 65 Celsius at load. Is this normal?
II:
a. Speed @ 4.7GHz --- Same restarting problem occurs but both the cases, the boot after this problem is smooth and doesnot have any effect.
b.Speed @ 4.7Ghz ---- Temperature @ Idle : 50Celsius Temparature @ load: 97Celsius ( In prime95 , two cores actually reached 98C, but did not shutdown. It ranged from 89C to 98C for nearly 45 min, then eventually I stopped).. Is this temperature ok?
I have applied TX-3 Thermalpaste ( First time user of CPU, hence I am not sure i applied well, but I believe i did ok in that job) and Cooler Master Hyper 212+ Cooler with one fan.
CASE : Thermaltake Element G with 5 Fans
So, to sum up my doubts :
1. Is this booting sequence normal or something is wrong that I should not overclock?
2. The temperature seems to a bit out of control for the paste and fan I use. Should I do anything or this temperaturess are normal at the speed?
3. Automatically, in Bios, the RAM speed is set to 1333Mhz but mine is rated at 1600MHz, so should I change it manually?
The most frustrating of all is :
It has four USB 3.0 Ports, two is given by a bracket and two built in motherboard. When Connecting my WD Passport HDD through the USB 3.0 ports(built in), every few seconds it disconnects and reconnects. Even after clean install of Windows, this happens. But connecting through the USB 3.0 brackets provided by ASUS connects without a problem. It has anything to do with the motherboard or everyone experiencing such problems?
Note : a. I have updated the bios to latest 1502 version
b. My windows 7 is upto date with SP1 ( The USB problem occurs even without Updates )
Guys, please help me out as this is my priced possession and I love these too much that I have slept sparsely since I built this system.
Regards,
Arun.S
My problems are :
I:
II:
Regards,
Arun.S
