How to connect Ethernet(RJ45) cable to DSL port of the modem
Last response: in Networking
Hi All,
I have a wireless modem with 6 ports(1 DSL port,1 VOIP port & 4 LAN ports) but the cable that carries my internet connection has RJ45 plug(This is what he told when i asked him)..
I want to set up wirelss connection with the above mentioned modem..so i tried to insert my internet cable into the DSL port of the router but it does not fit...
Can any body tell me what should i do?
Is there any converter available for Ethernet cable to DSl port...
Please help..
No. To connect to a modem, you need a router designed for use with a separate modem.
The best bet is to buy one of those -- or to remove the present modem if you can and replace its function with the on-board DSL modem in your present router.
Ask the community
