I just curious what is the best triple monitor setup to run with eyefinity?
I was thinking 23" - 24" monitors though I'm flexible on the size just nothing smaller than 23". I have plenty of power behind it w/ 2x6970s in crossfire. I know I need a ADP adapter and plan to get one. I'd like to keep this buy on a budget say around $800 if possible. Just looking for ideas. I've researched a lot of screens but thought I'd open it up to you guys maybe you've had better luck.
Thanks in advance for your help.
