Ok so I am wanting to build my FIRST PC and i was wondering if the components ive chosen along with the help of some YouTube videos will all be compatible with each other. I was also wondering with the CPU i am buying, will i need to buy a Cooler or is that included with the package in the CPU. Thanks so much please give me any information you have, this is my first time and im sure you remember yours so help a noobie out! Tysm <3
MOBO: http://www.newegg.com/Product/Product.aspx?Item=N82E16813138296
RAM: http://www.newegg.com/Product/Product.aspx?Item=N82E16820134792 (chose this specific RAM because of motherboard's manufacturer's recommendations, fits the DDr3 1333 240 pin slots the MOBO has)
PSU: http://www.newegg.com/Product/Product.aspx?Item=N82E16817171052
Video Card: http://www.newegg.com/Product/Product.aspx?Item=N82E16814161315
CPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16819115078
Other components like the CD Drive and Case will be Reused from previous PC.
Please let me know if there are any cheaper components i can buy that wont affect the performance, i am really on a budget of $550 and i am building this pc because i know it is cheaper this way. I am taking a leap of courage since i have never done this before and I'm really hoping for some guidance from the community. Thanks so much!!
