Solved
Need advice on ~$850 build
Approximate Purchase Date: Within a month.
Budget Range: Up to $850.
System Usage from Most to Least Important: After Effects, Vegas Pro, Photoshop, CoD, transcoding raw HD footage.
Preferred Website(s) for Parts: newegg.com & microcenter.com
Country of Origin: USA
Overclocking: Yes
SLI or Crossfire: Eventually.
Hello everyone,
I'm new to the build scene and I've spent some time configuring this on newegg and was wondering if anyone could give me some redecommendations or advice - it would all be greatly appreciated!
i5-2500k ($224.99) ($179.99 at microcenter)
ASUS P8P67 Pro R3 ($189.99)
G.Skill Ripjaws X 8GB (2x4GB) DDR3 1333 (PC3 10666) ($84.99)
MSI Hawk Radeon 5770 1GB ($139.99)
Raidmax Hybrid 2 530W Modular LED PSU ($39.99)
Cooler Master Elite 310 Case ($39.99)
WD Blue 500GB SATA 7200rpm 6Gb/s HDD ($44.99)
Cooler Master Hyper 212+ ($34.99) ($29.99 at microcenter)
2x Cooler Master 120mm Case Fan ($8.99/ea)
Price from newegg: $817.89
Price from newegg & microcenter: $767.89
Now the things I'd like to accomplish with this build are as follows:
Overclock to 4.5GHz+
Eventually crossfire.
Plan to buy a more powerful PSU if I ever crossfire.
Keep noise level below ~25-30dBA.
Excellent cooling.
That's all folks, but I'm looking forward to any recommendations you have for me!
-Leetsauce
4 answers Last reply Best Answer
More about need advice build
  1. Best answer
  2. Please see the PSU guide linked in my sig. You would have to work pretty hard to find a worse PSU choice.
    You do not need a lot of PSU to CF 5770s. A full system with 5770 CF is going to pull well under 500W. Just get a decent one now. Here is a way for you to get everything you need:
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.631331
    If you really want the case you chose, just add this PSU:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817151096
    That's a very high quality, very quiet PSU that will handle your CF needs.
    Or this is pretty much the same PSU re-branded by Antec:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817371031
    A bit less and has a promo code, but note the difference in warranties. Antec 3 years Seasonic 5 years.
    Edit because my sig had vanished.
  3. @asantesoul
    Those video cards are just a little out of my price range - but interesting that you recommend nvidia over ATI.
    As for the motherboards, ASRock is the "cheaper" brother board of Asus, and I haven't heard much about Gigabyte.
    Thanks for the PSU suggestions, the corsair ones are pricy though, I'm thinking I might need to go with a seasonic.
    @Proximon
    Thanks for the PSU tips! Glad to hear that the 5770 doesn't take much power. That seasonic is looking like a much better buy then the raidmax. Shame it doesn't have blue LED's though, but I think I can get by without those.
  4. Best answer selected by Leetsauce.
Build Systems Product
