I want to upgrade a HP p6710f with a new graphics card, case and power supply this summer. The specs are :
General Spec
Brand
HP
Series
Pavilion
Model
p6710f (BV530AA#ABA)
Type
Home / Home Office
Processor
AMD Athlon II X4 640 3.0GHz
Processor Main Features
64 bit Quad-Core Processor
Cache Per Processor
2MB L2 Cache
Memory
4GB DDR3 1333
Hard Drive
1TB 7200RPM SATA
Optical Drive 1
DVD SuperMulti Drive with LightScribe
Graphics
ATI Radeon HD 4200 integrated graphics
Audio
Sound card - Integrated
Ethernet
Fast Ethernet
Wireless Card
Wireless LAN 802.11b/g/n
Keyboard
HP USB keyboard
Mouse
HP USB Optical Mouse
Operating System
Windows 7 Home Premium 64-bit
Motherboard
Chipset
AMD 785G
CPU
CPU Type
Athlon II X4
CPU Speed
640(3.0GHz)
L2 Cache Per CPU
2MB
CPU Main Features
Graphics
GPU/VPU Type
ATI Radeon HD 4200
Graphics Interface
Integrated video
Memory
Memory Capacity
4GB DDR3
Memory Speed
DDR3 1333
Form Factor
DIMM 240-pin
Memory Spec
2GB x 2
Memory Slot (Total)
4
Memory Slot (Available)
Maximum Memory Supported
16GB
Hard Drive
HDD Capacity
1TB
HDD Interface
SATA
HDD RPM
7200rpm
I want to put it in this case:
Thermaltake Black SECC Japanese steel LANBOX Lite VF6000BWS Micro ATX Media Center / HTPC Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811133044&cm_re=thermaltake_case-_-11-133-044-_-Product
and use this power supply:
CORSAIR Builder Series CX430 CMPSU-430CX 430W ATX12V Active PFC Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139017&cm_re=corsair_power_supply-_-17-139-017-_-Product
and use a:
ZOTAC ZT-50401-10L GeForce GTX 550 Ti (Fermi) 1GB 192-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814500193&cm_re=550_ti-_-14-500-193-_-Product
or
HIS H577FK1GD Radeon HD 5770 (Juniper XT) 1GB 128-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card w/ Eyefinity
http://www.newegg.com/Product/Product.aspx?Item=N82E16814161338&cm_re=5770-_-14-161-338-_-Product
Is all the stuff going to fit in the case? Power supply enough? What graphics card is better for value?
Thanks
General Spec
Brand
HP
Series
Pavilion
Model
Type
Home / Home Office
Processor
Cache Per Processor
2MB L2 Cache
Memory
4GB DDR3 1333
Hard Drive
1TB 7200RPM SATA
Optical Drive 1
Graphics
Audio
Ethernet
Fast Ethernet
Wireless Card
Keyboard
HP USB keyboard
Mouse
Operating System
Motherboard
Chipset
AMD 785G
CPU
CPU Type
Athlon II X4
CPU Speed
640(3.0GHz)
L2 Cache Per CPU
2MB
CPU Main Features
Graphics
GPU/VPU Type
ATI Radeon HD 4200
Graphics Interface
Integrated video
Memory
Memory Capacity
4GB DDR3
Memory Speed
DDR3 1333
Form Factor
DIMM 240-pin
Memory Spec
2GB x 2
Memory Slot (Total)
4
16GB
Hard Drive
HDD Capacity
1TB
HDD Interface
SATA
HDD RPM
7200rpm
and use a:
or
Thanks
