Help with my Build ~$1100
This is my pure gaming build. I'll have it set up in a spare room and only use it when I'm playing games. When not in use, I'm powering it down. I'd like to make the build as future proof as possible since I'm planning on Crossfire 6950's later (a year or two). If you see anything wrong or where I could improve with my build, please, help me out. Thanks for looking.
Approximate Purchase Date: Week or so
Budget Range: ~$1100
System Usage from Most to Least Important: Gaming.
Parts Not Required: Just need the PC. Nothing else.
Preferred Website(s) for Parts: newegg, unless there's a big difference.
Country of Origin: USA
Parts Preferences: Whatever's Good.
Overclocking: Yes (this will be my first time)
SLI or Crossfire: Crossfire in the future
Monitor Resolution: 1920x1200
Additional Comments:
Case: Antec 900 $99.99 +15.99 Shipping
Reason I went with it was pretty simple. It's a great case, and I wanted plenty of room. This will fit two 6950's in it right?
Mobo: ASRock P67 Extreme 4 LGA1155 $159.99 + $8.50 Shipping
I went with it because people say it's a very easy OC mobo. I've never done any OC'ing so I wanted it to be as easy as possible.
CPU: Intel i5-2500K 3.3ghz $224.99
Again, heard this was the best at OC'ing. Easy and powerful for gaming.
CPU Heatsink: Cool Master Hyper 212 $34.99 +7.56 Shipping
This is one area I honestly have no idea. I heard it was a good one, better suggestions here would be greatly appreciated.
GPU: MSI Radeon HD 6950 2GB $279.99 + $8.50 Shipping (also has a $30 MIR)
I want to unlock it to a full Radeon HD 6970.
RAM: GSkillz Ripjaws 8GB 1600 DDR3 $99.99
My idea was to future proof my system as much as I could. Buy 8GB of ram now so I don't have to upgrade later if I only get 4GB.
PSU: Corsair HX Series 750W $139.99 + $5.99 Shipping (Also a $10 MIR)
This was another future proofing idea. Some point down the road I want to Crossfire two 6950's and this PSU gives me the ability to do just that. Also while it's rated at a Silver 80plus certification, it's actually a 90% efficient PSU. Figure, spend a little more now. Save down the road.
HDD: Samsung Spinpoint F3 1TB 7200rpm $64.99
Heard it was the best or one of the best non-SSD hard drives out there.
DVD: Liteon DVD Burner $20.99
Mainly picked it because of free shipping and tons of good reviews. I'll only even use my DVD player to load windows and games on it.
Toss in some Arctic Silver Compound and my grand total before shipping and MIR's (which I figure will about break even) is $1,132.89.
8 answers Last reply
More about help build 1100
  1. the coolermaster is good, but for $20 more you can get one of Frostytech's top-5 heatsinks, the Thermaltake Frio, at $57.99:
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835106150
  2. http://www.amazon.com/Antec-Mid-Tower-Gaming-Hundred-V3/dp/B004ALI5KC/ref=sr_1_4?s=pc&ie=UTF8&qid=1303950933&sr=1-4 $119.99 & this item ships for FREE with Super Saver Shipping
    Antec Mid-Tower Gaming Case Nine Hundred Two V3
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811129097 <---- Here's that same Antec 902 v3 @ newegg + shipping.
    http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.624838 $194.98 - $10.00 Mail In Rebates
    CORSAIR HX Series CMPSU-750HX 750W ATX12V 2.3 / EPS12V 2.91 SLI Ready CrossFire Ready 80 PLUS SILVER Certified Modular Active PFC Power Supply
    SAMSUNG Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
    http://www.amazon.com/Cooler-Master-Hyper-Sleeve-RR-B10-212P-G1/dp/B002G1YPH0/ref=sr_1_1?s=pc&ie=UTF8&qid=1303777065&sr=1-1 $29.15 & this item ships for FREE with Super Saver Shipping
    Cooler Master Hyper 212 Plus 120mm Sleeve CPU Cooler, RR-B10-212P-G1
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820231416 $69.99 FREE SHIPPING
    G.SKILL Sniper 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBSR
  3. Is the 902 v3 better than the 900? I've read reviews where the 902 is actually harder to fit some components in it.
    Those combo deals are awesome though! Definitely going to go with them. And I like the sniper memory even better than ripjaws. That's a great $30 savings. Thanks!
    If you go with the 900, grab it off of amazon...it's free shipping on there. Also that Asrock board come with a black front USB 3.0 panel with a 2.5" SSD bracket that would look nice on that Antec 900.
    http://www.asrock.com/mb/overview.asp?Model=P67%20Extreme4 <---- It shows it about halfway down on that page there.
  5. I was curious, what about an all enclosed liquid cooling solution maybe like this one?
    http://www.newegg.com/Product/Product.aspx?Item=N82E16835181010
    Is it worth the extra money to drop the temp a few more degrees?
  6. I'm personally biased against liquid cooling due to increased maintenance issues, Air cooling just needs you to blow the dust out every few months. Liquid needs assurance that its not leaking. Constantly
  7. With a good 3rd party heatsink you will get great performance overclocking on the Intel Core I5 2500K without having to worry about water cooling. Heck I have heard of people hitting upwards of 4.5 GHz with the stock heatsink so that should give you an idea who what you can get out of it with a good air.
    Christian Wood
    Intel Enthusiast Team
  8. Thanks for the input! I suppose for my first OC build I should use the KISS method. I'll have enough to deal with just using the OC'ing software, much less having to worry about a leak.
Build Gaming Systems Product
